I am restoring the power supply from the Agilent 54845A and changing the capacitors.
I plan to replace the capacitor in the primary power supply circuit 450V 470uF. It just uses a specific type with 4 pins, two of which are for mechanical fixation. There is no problem in buying such capacitors with 10mm snap-in pins, but the capacitor (40mm height and 450/470uF) with 4 pins is not available.
The power supply uses 40x40 Nippon Chemicon KMH 450V 470uF 4pins, 22.5mm between pins space.
In general, I always buy capacitors only through DigiKey and other similar distributors, since most likely a fake will come from China and this is difficult to prove.
I see a great option on Ebay:
https://www.ebay.com/itm/153789260112But the pins are straight (and should be bent to snap into place), this is probably a fake. What do you think?
