Author Topic: Hakko FM-203 & FM-2024 Setup  (Read 7363 times)
Offline HamsterTopic starter
« on: October 07, 2013, 12:36:35 am »
I recently upgraded my 3 set of Soldering/Desolding tools..
First a plug in, then a Weller adj, then a circuit specialties dual solder/desolder which died, then a mcm unit.. loved them all, but figured i would since upgrade.. Someone gave me a ikon fx1? soldering station and got spoiled over the fact it heated up super fast & had an idle timer.
I ended up buying the FM-203 and FM-2024 Unit , and various tips for it, i would have to say, hands down this is a very nice setup, works very well, i like the fact you can pop off the tips, and change to a different sides very quickly, and effortlessly, the setup has very good temperature stability and I am very pleased with the setup. I am not sure i can ever go back to another unit. I have used it to do SMT work, and though hole work without issue., large tip size doesn't have a problem melting large solder pads for desoldering, i was able to also remove DIP-40 packaged from a Dual layer board very easy ( instead of clipping the legs and pulling a leg out at a time )
Caveats.. The FM-2024 Station require pressurized air to function, it does not have a "Vacuum" pump integrated into it, i am currently using a small 2 stage air brush compressor with a small reservoir can, works great!
I also have a FX-901 handheld Soldering iron that runs on 4 AA batteries, has a good weight, but have not given it a test yet, i will post after i have..
any questions feel free to ask, and i will give my best opinion/answer :)
Arcade Board Repair Guru.  [ twitch: HammysHangout , youTube: Hammy Builds ]
Offline DL8RI
Re: Hakko FM-203 & FM-2024 Setup
« Reply #1 on: October 07, 2013, 06:28:04 pm »
just a little warning:
Neverever(!!) remove the headphone-jack on the holder when the station is turned on. I killed my FM206 with this. :-BROKE
Maybe this one is designed better, but be careful.
Offline tolit_02
  • Country: ph
« Reply #2 on: November 24, 2018, 08:44:11 am »
hi sir i want ask. i have hakko fm-2024  with control box  do i need external vacum pump to work  the control box of hakko fm2024
and what type of compressor
air pressure or air vacuum
« Last Edit: November 24, 2018, 10:00:05 am by tolit_02 »
Offline deano76
« Reply #3 on: May 13, 2023, 06:25:10 pm »
I'm setting up my FM-2024 and have the same question as below - do you contact to an air compressor (as the instructions suggest) or a vacuum pump (which would make more sense!).
Offline thm_w
  • Non-expert
« Reply #4 on: May 16, 2023, 12:23:24 am »
Yes you follow the instructions: " the Desoldering Control Module also requires shop/compressed air"
You can read more here:
https://www.nexflow.com/blog/venturi-system-vs-vacuum-pumps/
https://www.blowervacuumbestpractices.com/system-assessments/vacuum-generation/utilizing-venturi-vacuum-generators-efficiently
« Reply #5 on: June 26, 2023, 03:59:48 am »
I am using a California Air Model #2010A compressor
Offline Arts
« Reply #6 on: June 27, 2023, 09:27:44 pm »
Wow, that's a scary thought! Was there any mention of this in the manual? I have an FM-203 running the FM-2027 & FM-2030 (HD) irons, so I occasionally move the iron holders around on the bench, depending on which I'm using. And the connecting cable doesn't use a locking plug...
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #7 on: October 14, 2023, 01:07:57 am »
I been using a Dual 203 / C1492 Setup for a few years I really like it. Switching my main station over to JBC will demote the Hakko to back up / second bench. No issues unplugging the sleep while hot do it all the time on the 203.
« Reply #8 on: October 15, 2023, 05:47:47 pm »
yes, its mentioned on several placed, never unplug the cable while its on.
« Reply #9 on: October 15, 2023, 05:49:49 pm »
Thoughts on your reasoning to switch? I am not sure i can afford to abandon my Hakko Station.
maybe i can use it to offset my twitch income lol.. 5 year business loss lol.
really do like the looks of the JBC DDSE-1QD
« Last Edit: October 15, 2023, 05:51:59 pm by Hamster »
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #10 on: October 17, 2023, 12:44:29 am »
Hamster, No real reason to switch just something to do.
« Reply #11 on: October 19, 2023, 03:24:31 pm »
I noticed the JBC has its own internal pump, reducing the reliance on shop air.
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #12 on: October 19, 2023, 05:58:36 pm »
Yea, As soon as funds allow or I find someone to swap with I am going to go to a shop air unit.
Offline Arts
« Reply #13 on: October 20, 2023, 06:18:34 pm »
I've found that the JBC product line is very reliable. I've had this desoldering unit forever, and for small diameter work the original tip it came with is still perfect :)
