Good thought. Bidirectional communication would also explain the two different levels of low pulses (600mv and 200mv).
Definitely it is like you said.
I have bought Powerworks 60V mower cheap without battery.
My idea was to run it with 3x Makita 18V batteries which I have a lot.
To make it run I have modified Arduino sketch available on Endless sphere thread.
I simply removed second part of a script to check if the answer form mower will still appear on a bus. Indded it was.
Unfortunatley this was not enough for reliable opration. Mover turns off after 1-2 min of running with 6 loud beeps.
Reading carefull this thread and endless sphere theread I figure out that query frame is not the same all the time.
Dumb luck I was able to generate different random query and sitll receive answer from mower.
https://youtu.be/Y7Tlfim-A8wI tried to alternate this query every 2sec. and to my surprise it works!
I was able to mow grass in my entire garden for ~60min.
https://youtu.be/ER4f0lgI0SA Preliminarly I was worried about lack of power in battery powered mower.
Mower draws only ~5A continous, 10A max and this reflecs to only 300 - 600W of power, compared to 2-3kW gas powered mowers.
However it turns to be opposite - gas powered mowers seems to be overpowered for such simple task as grass cutting ;-).
BTW. to power Arduino form 5V you do not need separete DC/DC 60V to 5V converter.
5V is available at motor hall sensor harness!
Here is my working Arduino sketch:
// written 5/26/2020
// Working battery interface signal from the "Omega" port
// of a Greenworks Pro 60V batter
//20.05.2021 BornToRepair mod:
//reply frame removed
//pin6 input mode enabled beetween query frames
//query cycling each 2000ms
#define PIN 6
void setup()
pinMode(PIN, OUTPUT);
void loop()
for(uint8_t a = 0; a < 10; a++)
digitalWrite(PIN, HIGH);
//Delay 188,000us
for(uint8_t i = 0; i < 188; i++)
delayMicroseconds(1000);
digitalWrite(PIN, LOW);
delayMicroseconds(400);
for(uint8_t i = 0; i < 4; i++)
delayMicroseconds(100);
delayMicroseconds(200);
for(uint8_t i = 0; i < 10; i++)
for(uint8_t i = 0; i < 1; i++)
// 5
for(uint8_t i = 0; i < 3; i++)
for(uint8_t i = 0; i < 2; i++)
pinMode(PIN, INPUT);
//Delay 188,000us
for(uint8_t i = 0; i < 9; i++)
// 5
