Author Topic: Greenworks 60v battery Ohm terminal  (Read 28492 times)
Offline BradK
Re: Greenworks 60v battery Ohm terminal
« Reply #25 on: February 28, 2021, 11:45:02 pm »
Thanks for sharing.
I just bought a 60V 4Ah GW battery-should be here on the 8th. Once I get it I'll post the data from the logic analyzer as well.
I'm still confused how those on the other forum got it working and we did exactly what they mentioned with no luck? Hopefully we'll figure it out.
Offline typoknigTopic starter
« Reply #26 on: March 01, 2021, 03:20:43 am »
GreenWorks: 1, Typoknig: 0
I have produced the signal within 2us of precision and used the 5 unique initialization pulse groups, but that is apparently not good enough.  I set up my scope to record both the GW battery Omega pin signal and the signal generated by the Arduino at the same time and had the Arduino start generating the signal at the same time (there was about a 50us delay for the Arduino starting because I was using the GW battery Omega pin signal as a trigger) and the wave forms are essentially on top of each other with only very minor differences that I'm unable to remove due to the precision of the Arduino.
I felt I had exhausted all possibilities trying do duplicate the signal without knowing more about the actual data.  I didn't think that GW would bang out their own protocol, so I took the battery apart to seen what was inside.  No surprise, it was potted just like the snow blower controller, but it wasn't nearly as thick.  There was one large chip that looked like it might be a controller, so I scraped off the potting material and found it is a Renesas R5F100ACA.  Datasheet from Mouser attached.  I'll dig into the datasheet this week to see WTF this chip wants from us, but the first thing I noticed is that it is a 32MHz chip compared to the Arduino Nano which is only 16MHz.  That could definitely cause a resolution problem.
Also attached is a spreadsheet of the pulses I recorded from my scope. The actual pulses were often a fraction, so I always rounded down to a whole number.
« Last Edit: March 01, 2021, 05:13:54 pm by typoknig »
The following users thanked this post: samocos191
Offline BradK
« Reply #27 on: March 05, 2021, 08:57:08 pm »
My GW battery arrived yesterday.
I looked at the signal on the scope and it looks exactly like the one I'm producing with the Arduino code.
I thought like you said it might be the voltage difference (+5V Arduino vs +2.3V GW batt) so I hooked up a POT and used it as a voltage divider to take the signal down to about 2.3V...Still didn't run (I used a 2k pot-perhaps it also needs a specific current?). I also noticed like you said the initial pulse group only went low to about 60mV and the 2nd pulse group went to about 20mV?
I will try connecting to my logic analyzer sometime this weekend but so far everything looks fine on the scope?
I guess if this doesn't work I'll just keep the GW battery and use my additional batts with it to give me a longer runtime.
« Reply #28 on: March 06, 2021, 03:30:25 am »
Don't give up!  That's what they want!  :)
I haven't had a chance to dive into the datasheet I posted.  That controller is complex enough that nothing was jumping out at me at first glance.  I also had to send my scope in for service so I'll be without it for a couple of weeks.
Here is one thing that give me hope though.  If this is a timing issue (which is still one of the most likely cases) here is post about producing sub microsecond accuracy.  I haven't had a chance to implement it yet, but I did notice that a lot of the pulses from the GW battery were XX.5us, so the method described in this post could help us get closer to that mark:
https://forum.arduino.cc/index.php?topic=96971.0
Offline BradK
« Reply #29 on: March 06, 2021, 08:54:30 am »
Hooked everything up to the logic analyzer tonight,
For some reason (probably me) I am only getting the signal from the Arduino to come up on the logic analyzer.
I have the signal from the Arduino adjusted to 2.3V. I have never used a logic analyzer so I'm sure its something I'm doing wrong...Perhaps the GW batt signal not going to 0V is the problem, I'll try a few different triggers tomorrow and see what I can get.
Offline BradK
« Reply #30 on: March 06, 2021, 09:40:44 pm »
Good news,
I found my mistake (grounding issue on the GW signal-logic analyzer) and captured both signals.
You can see many differences between them on the PDF screen capture (attached).
Channel 0  (top) is the signal from the Arduino, Channel 1 (bottom) is the GW battery.
Typoknig, like you mentioned there are some differences in pulse lengths etc.
Now the bad news, I know very little about 'decoding' the signals and changing the Arduino code to match it. The only thing I know how to do is put my cursor on each pulse and compare the measurements.
I tried attaching the file but it is not an 'Allowed File Type'.
Offline BradK
« Reply #31 on: March 06, 2021, 10:56:02 pm »
For anyone who wants the original file:
Download the free logic analyzer software @ https://www.saleae.com/downloads/
Send me a PM with your email and I will email you the .logicdata file.
UPDATE: So I have been going through the signals and found 26 mismatches on both High and Low pulse widths.
More to come...
« Last Edit: March 07, 2021, 02:03:41 am by BradK »
Offline BradK
« Reply #32 on: March 08, 2021, 07:35:34 am »
Here's where I'm at:
Measured GW batt logic using a sample rate of 16Ms/s.
Compared High and low pulse lengths-noted mismatches.
Wrote a program for my nano, rounding the high and low pulse lengths to the nearest uS.
Signal looked good on scope, connected voltage divider to produce 2.3V peak and connected to mower.
   *Result: Beep beep beep!
Thoughts/troubleshooting:
1. Code not precise enough (although other forum users claimed theirs worked?)
2. Timing between applied power and signal needs to be precise (Right now I have my Arduino powered by a separate PS-I wonder if the Mower has to see the signal within ____mS of seeing 60V power?
3. GW pulse pattern LOWs do not go all the way to 0V as stated by Typoknig.
After this I looked over my Arduino code, made a few changes and found an error that I fixed and then uploaded the new program and tried it again. Result, Beep beep beep. I'm getting really tired of hearing those beeps, I feel like the mower is laughing at me.
Tomorrow I will connect the Arduino to the batteries in hopes of testing if the timing between applied power and the signal is the problem, but I am doubting it. Here's the Arduino code I wrote so far:
void setup()
pinMode(6,OUTPUT);
void loop()  {
digitalWrite(6,HIGH);
delay(189);
digitalWrite(6,LOW);
delayMicroseconds(411);
ditigalWrite(6,HIGH);
delayMicroseconds(102);
delayMicroseconds(115);
delayMicroseconds(103);
delayMicroseconds(214);
delayMicroseconds(130);
delayMicroseconds(117);
delayMicroseconds(116);
delayMicroseconds(526);
delayMicroseconds(204);
delayMicroseconds(96);
delayMicroseconds(104);
delayMicroseconds(205);
delayMicroseconds(105);
delayMicroseconds(95);
delayMicroseconds(206);
delayMicroseconds(106);
delayMicroseconds(94);
If the timing test does not solve the problem I will probably look over the program a few more times, measure the GW sig at a higher sample rate and try to get more accuracy out ot it. If that does not work I'll probably give up and figure the problem is beyond my knowledge and just use the GW batt and my batts in parallel to at least double the run time.
« Last Edit: March 08, 2021, 03:13:10 pm by BradK »
Offline BradK
« Reply #33 on: March 08, 2021, 05:35:45 pm »
Today I connected everything to my batteries to see if the issue was timing.
Found out my 5V regulator circuit had a short in it and I overvolted my last Arduino Nano (+18V to +5V pin), CRAP!
I may order another Nano but right now this project has taken too much time from other projects.
I'm just going to wire up my existing setup to the mower and use it with the GW battery.
I am still confused how those on the other forum had success as their Arduino program did not even come close to matching what I am seeing coming from the GW battery???
« Reply #34 on: March 09, 2021, 03:27:22 am »
This is just a guess, but I suspect some of the older GW tools were a bit looser on their timing requirements, so the microsecond precision signal generated by an Arduino worked. I suspect newer tools implement another Renesas chip and the timing requirements are now in the nanosecond range which the Arduino can't do reliability via the delay function.
Offline NiHaoMike
    • Facebook Page
« Reply #35 on: March 09, 2021, 03:46:16 am »
My guess is that the line is a bidirectional bus (similar to 1Wire) and therefore imitating the waveform would only work if the playback starts at exactly the right time. Perhaps make a small inductive pickup to tell which end is driving the line while reverse engineering with the scope?
Offline BradK
« Reply #36 on: March 09, 2021, 04:17:47 am »
Typoknig,
I think your right...Very annoying since most tools use 18650s yet the manufacturers act like their batteries are special.
So far I've converted a weed eater, snow blower, power supply, and a water pump to run on my Ryobi batts.
NiHaoMike,
I think that is something to look into.
Perhaps a DPST switch to turn on both Arduino and apply 60V signals at the same time then add the initial wait time to the Arduino code?
I just ordered a few more parts and will try again in a few weeks.
But I do think Typoknig may be right about the sub uS requirement.
UPDATE: Tonight I soldered in the wires for my Ryobi batts and tested it with the GW batt in parallel. Works great. Can't wait to actually try this mower out on real grass.
« Last Edit: March 09, 2021, 07:56:42 am by BradK »
« Reply #37 on: March 09, 2021, 07:59:06 am »
Good thought. Bidirectional communication would also explain the two different levels of low pulses (600mv and 200mv).
Offline BornToRepair
« Reply #38 on: May 28, 2021, 06:57:51 pm »
Definitely it is like you said.
I have bought Powerworks 60V mower cheap without battery.
My idea was to run it with 3x Makita 18V batteries which I have a lot.
To make it run I have modified Arduino sketch available on Endless sphere thread.
I simply removed second part of a script to check if the answer form mower will still appear on a bus. Indded it was.
Unfortunatley this was not enough for reliable opration. Mover turns off after 1-2 min of running with 6 loud beeps.
Reading carefull this thread and endless sphere theread I figure out that query frame is not the same all the time.
Dumb luck I was able to generate different random query and sitll receive answer from mower.
https://youtu.be/Y7Tlfim-A8w
I tried to alternate this query every 2sec. and to my surprise it works!
I was able to mow grass in my entire garden for ~60min.
https://youtu.be/ER4f0lgI0SA
Preliminarly I was worried about lack of power in battery powered mower.
Mower draws only ~5A continous, 10A max and this reflecs to only 300 - 600W of power, compared to 2-3kW gas powered mowers.
However it turns to be opposite - gas powered mowers seems to be overpowered for such simple task as grass cutting ;-).
BTW. to power Arduino form 5V you do not need separete DC/DC 60V to 5V converter.
5V is available at motor hall sensor harness!
Here is my working Arduino sketch:
// written 5/26/2020
// Working battery interface signal from the "Omega" port
// of a Greenworks Pro 60V batter
//20.05.2021 BornToRepair mod:
//reply frame removed
//pin6 input mode enabled beetween query frames
//query cycling each 2000ms
#define PIN 6
void setup()
pinMode(PIN, OUTPUT);
void loop()
for(uint8_t a = 0; a < 10; a++)
digitalWrite(PIN, HIGH);
//Delay 188,000us
for(uint8_t i = 0; i < 188; i++)
delayMicroseconds(1000);
digitalWrite(PIN, LOW);
delayMicroseconds(400);
for(uint8_t i = 0; i < 4; i++)
delayMicroseconds(100);
delayMicroseconds(200);
for(uint8_t i = 0; i < 10; i++)
for(uint8_t i = 0; i < 1; i++)
// 5
for(uint8_t i = 0; i < 3; i++)
for(uint8_t i = 0; i < 2; i++)
pinMode(PIN, INPUT);
//Delay 188,000us
for(uint8_t i = 0; i < 9; i++)
// 5
« Last Edit: May 28, 2021, 07:13:07 pm by BornToRepair »
Offline james_s
« Reply #39 on: May 29, 2021, 12:41:03 am »
Maybe you can find a worn out battery to reverse engineer? Once a tool has been out for a while there should be some dead ones floating around.
Despite the hassles I do love my cordless tools and hate cords. I gave away all my corded electric tools except for my circular saw and miter saw. I gave away my gas lawnmower last year too, I have a small lawn and realized I was spending more time fussing with the carburetor than I was mowing.
« Reply #40 on: June 22, 2021, 08:52:52 pm »
Awesome!  It is hot AF in the Midwest right now, so this project has been on the back burner for me.  When we get closer to having snow again I'll give your mod a try.  It would be great to be able to do this with an Arduino and not have to upgrade to something faster.
« Reply #41 on: October 15, 2021, 01:33:51 am »
[url]https://youtu.be/Y7Tlfim-A8w[/url]
[url]https://youtu.be/ER4f0lgI0SA[/url]
#define PIN 6
void setup()
void loop()
//Delay 188,000us
// 5
//Delay 188,000us
// 5
Finally got back to this project and still can't get the snow blower working with your latest code.  Just runs for 3 seconds then shuts off like before.  Looking at the pictures I see that our PCB units are different.  Mine is part number 362011483AC and looks identical one I found on ebay (part number 362011205AB) which is for an 80V snow blower (see attached).
« Last Edit: October 16, 2021, 01:15:18 am by typoknig »
« Reply #42 on: October 28, 2021, 04:38:41 am »
I rolled the dice and de-potted my PCB to try and figure out what was going on.  Tragically, the PCB no longer works, but I still hope now that I can see the components used that I can determine what the exact signal is this thing wants.  I may take a stab at fixing it too before I spend $60 on a new one.
The PCB uses an ON Semiconductor FAN7888 as 3 phase motor inverter driver.  It is the large 20 pin SOIC package IC in the middle of the attached picture.  Datasheet also attached.
The PCB also has a meter IC which I'm unable to identify.  It is the small 8 pin SOIC package IC in the upper right corner of the attached picture.  It has the following markings, but where I use the asterisk the IC actually shows the diode symbol oriented vertically (anode top, cathode bottom) as if it were a character:
I*RP948G
9019
F6216
Finally, and most importantly, the IC has a controller IC which I am also unable to identify.  It is the 32 pin QFP package IC and it has the following markings and also has the characters "H65" in a circle to identify the first pin.  I was thinking that H65 in a circle might be a manufacturer identifier, but I can't find anything on it:
C009B2
020FZ02
Any help identifying these ICs would be appreciated.
« Last Edit: October 28, 2021, 04:45:40 am by typoknig »
Offline NiHaoMike
    • Facebook Page
« Reply #43 on: October 30, 2021, 03:50:30 am »
Perhaps consider replacing it with a generic BLDC ESC? A quick search finds quite a few 60V ESCs for scooters.
« Reply #44 on: October 30, 2021, 06:14:40 am »
That is a good idea. I did a quick search and I didn't see any that looked big enough. I'll check the motor specs tomorrow and try to find a good match. Still, I would like to find a solution that works without dismantling tools. I was hoping to be able to use all Greenworks tools with DeWalt batteries once I got this figure out. Didn't want a project each time, just wanted to put my frankenbattery in a tool and have it work.
« Last Edit: October 30, 2021, 06:18:25 am by typoknig »
Offline JunkPlusTools
« Reply #45 on: November 19, 2021, 06:28:01 pm »
Great info in this thread. I have a GW 60V trimmer that I bought for parts, and can confirm that when powered from a 66V battery with just + and - terminals, it runs for ~3sec then powers off. No audible beeper.
This is the trimmer with motor down at the bottom of the shaft. The motor is an outrunner, direct drive to the trimmer spool, marked Globe 60VDC. It has no hall sensors, just the 3 motor phase wires. Motor has forced cooling, unlike most hobby outrunners. Motor bearings come with a slight bit of play from the factory (maybe I got a bad unit, but the play seems in the bearings themselves). Discovering that it is sensorless, and only runs for 3 seconds without GW battery authentication - I don't think it's ideal for my project.
Question for you folks - if I buy a dewalt 60V tool, will it run from a generic 60VDC source, or does it also try to 'authenticate' the battery?
« Reply #46 on: November 23, 2021, 05:28:08 am »
I'll check and report back.  May not be till after Thanksgiving though.
« Reply #47 on: November 29, 2021, 11:15:19 pm »
I just checked to see if my DeWalt leaf blower (DCBL770) would run with only power and ground, and unfortunately it will not.  I didn't research any further, so making it work may be simple as jumping a few of the extra pins on the tool.
Offline softwarecrash
« Reply #48 on: January 21, 2022, 12:32:11 pm »
Hi there,
I have various Greenworks devices that I would like to use with other batteries.
I looked at the signal and wrote a small program based on it.
the program is designed in such a way that you can easily use other battery types.
unfortunately i don't have 60v and 80v batteries and can't reproduce the signal for them.
since the signal pauses are always the same length, i only need the pulse lengths and number of pulses, and what for battery and manufacturers.
like 1x400 3x200 13x102 .....
then i can include it in the program, maybe we can create a list with which manufacturers and battery types it works?
here the program
https://github.com/softwarecrash/OmegaFaker
by interesed, i think about a self learn function or a function to read out the battery and report the sequel by serial
« Last Edit: January 21, 2022, 12:44:04 pm by softwarecrash »
« Reply #49 on: January 21, 2022, 05:19:22 pm »
Hi there,
here the program
Check the attachments in this post:
https://www.eevblog.com/forum/reviews/greenworks-60v-battery-ohm-terminal/msg3488428/#msg3488428
You can also look at the Arduino programs that I and others have posted which typically have tables of pin high/low hold times.
I hope you have better luck with the 60v Greenworks system than I've had.  The only Greenworks tool I have is the 60v snow blower.  The programs I've written for the Arduino and those I have tried from others have not worked.  I believe this is either because the Arduino can't produce pulses precise enough for the Renesas IC to consider valid (Arduino is 8 bit and 16 MHz and the Renesas R5F100ACA used by the Greenworks battery is 16 bit and 32 MHz), or because there is some logic that won't accept the exact same series of pulses over and over again.
« Last Edit: January 21, 2022, 05:33:21 pm by typoknig »
