Is it possible to get schematics for this meter anywhere?
Do you mean that you have to zero the meter each time you change ohms range? If so, that is normal for an analog meter.
About the AC Volts.The Metrahit is a averaging Meter, the Fluke has True RMS capability, maybe that's the reason for the discrepancy.But 28V difference seems a bit much, assuming you measureing mains.
Quote from: Fox on May 28, 2012, 01:38:34 pmAbout the AC Volts.The Metrahit is a averaging Meter, the Fluke has True RMS capability, maybe that's the reason for the discrepancy.But 28V difference seems a bit much, assuming you measureing mains.Fox, I think you're reading off the wrong scale.
