Wow. Talk about a long time to market. I was going to start a new thread but I figured I've revive this one.
Looks like they are finally releasing their DSO8000E and DSO1000E handheld scopes....
http://www.hantek.com/en/ProductDetail_1_159.htmlhttp://www.hantek.com/en/ProductDetail_1_158.htmlDSO8000E Specs:
Six in one: Oscilloscope/Recorder/DMM/ Spectrum Analyzer/Frequency Counter/Arbitrary Waveform generator.
IP-51 rated for dust, drip and shake proof to withstand harsh environments.
Large fuse confirms to European Safety Standard.
Battery indicator with easy-changed connect points. Selectable 18650 battery box for matching 18650 battery by yourself.
Anti-theft lock hole, tripod fixed hole, hang rope, FLASH light that can be used in darkness.
Replaceable BNC safety joints, and additional one set of joints.
High bandwidth 70MHz-200MHz Oscilloscope, 1GSa/s sample rate, 2M Memory depth.
25Mz Arb. Waveform Generator, 200 Mesa/s DDS, 12 bit vertical resolution, easy for simulating transducer
6000 Counts DMM, AC/DC voltage, AC/DC current, resistance, break, capacitance, and diode function.
FFT spectral analysis; Waveform Math: add, subtract, multiply and divide; X-Y mode; more than 20 automatic measurements; PASS/FAIL Check function, apply to engineering application.
Abundant trigger function, double timebase sampling, easy to observe two waveforms in different frequency.
Record and replay of more than 1000 waveforms.
Large 5.6 inch TFT Color LCD Display; High Resolution(640*480)
USB Host/Device 2.0 full-speed interface; support removable disk; WIFI/LAN Option, easy to control by PC or long-distance.
Waveform data can be output in WORD?EXCEL, BMP, JPG as time and voltage.
