Author Topic: Getting quality solder in Europe (Norway)  (Read 9326 times)
Offline Ysjoelfir
Re: Getting quality solder in Europe (Norway)
« Reply #25 on: April 17, 2019, 07:21:30 am »
Reading that I'm quite happy that I have quite a stockpile of leaded solder flying around in the lab... Even though I tend to use leadfree most of the time (Stannol Kristall... IIRC 400, but I would have to check to be sure), at least for my all-day work, not for repairing older stuff - that's where the good old leaded solder comes to work  >:D
Greetings, Kai \ Ysjoelfir
Offline not1xor1
« Reply #26 on: April 17, 2019, 08:01:46 am »
BTW what is the difference between SnPb and SnPb+2%Cu ?
On TME catalog the Cu alloys are specified for a lower fusion temperature (183°C against 190°C of 60/40 SnPb).
What about reliability?
Offline helius
« Reply #27 on: April 17, 2019, 08:32:37 am »
The liquidus of Sn63Pb37 is also 183°C.
The addition of copper was required to extend the life of unplated copper tips, when those were common 50 years ago. It also improves the strength of the joint, which is not needed in most electronics.
Offline Thomas
  • Country: no
« Reply #28 on: April 17, 2019, 08:35:52 am »
Don't bother trying to buy leaded solder from Elfa unless you are a business.
I tried earlier this evening to put some in my basket only to have the site tell me it is only available to business customers.
Like I'm going to use lead free solder to repair things like 30 year old bench multimeters.  :palm:
These rules are made by idiots!
Some of them can be added to the basket, I don't know why :-//
Offline grizewald
  • Country: ua
« Reply #29 on: April 17, 2019, 09:51:27 am »
Truly bizarre! Out of all the alloys which include lead, I was able to add 10 out of 84 to my basket.  :-//
I ordered some nice Polish 60/40 solder from eBay instead.  :-+
  Lord of Sealand
Offline Star1Topic starter
  • Country: no
« Reply #30 on: April 17, 2019, 12:27:24 pm »
I could add only 2 with a diameter of 0.5mm or less, and the least expensive one was something like 100USD, so that is a no go.
I think I might have to go for that same Polish 60/40. I'd really like to try 63/37, but as it looks now even a small spool would cost more than both my soldering irons :P
Offline Brutte
« Reply #32 on: April 18, 2019, 11:09:09 am »
Keep in mind there are different solders with different compositions.
I am afraid even when you buy the best Sn96Ag4, it will be nowhere near the worst Sn60Pb40 (when compared the mechanical properties, melting point etc). Add to that the decision about flux - there are dozens of different flux types, more and less agressive, no clean etc and of course there is a solid core solder without flux.
The Pb free solder for rework that I can recommend is Sn96Ag4 which is quite pleasant in use but since it is 4% silver, it is not cheap and it melts at 220degC.
Then - there is no significant difference in between soldering with Sn99.7Cu0.3 and soldering with a paperclip IMHO  |O. Any Pb-free rework with this 0% Ag thing requires top notch soldering iron plus a lot of flux and patience.
1kg of Sn60Pb40 is around $25 and 1kg of Sn96Ag4 is $100 (1mm).
  • Country: no
Online stj
« Reply #34 on: April 18, 2019, 11:46:11 am »
get a decent iron and learn how to solder.
i use that formulation for years - no problems at all.
it helps if it has the right flux INSIDE it, preferably KRISTALL505/511 or HS10
Offline sn4k3
  • Country: pt
« Reply #35 on: April 18, 2019, 01:09:46 pm »
If you go AliExpress route I advice go for Wit solder from Japan. It's very good, no very bad smalls, no splattering and is really 183°c melting point, this is of course pb solder but they also have lead free
https://s.click.aliexpress.com/e/yiGyVf6
I use that and is great, even better than some expensive brands I used before (for rework)
« Last Edit: April 18, 2019, 01:14:04 pm by sn4k3 »
Offline salavat
  • Country: ru
« Reply #36 on: April 19, 2019, 05:18:18 pm »
One of the best solders I've tried  is Felder solder (Felder is German company). Can you order from Germany?
  • Country: no
« Reply #37 on: April 19, 2019, 08:16:23 pm »
That depends on the Germans :P
All I need is a webshop that is willing to ship to Norway to order from anywhere.
Offline tooki
« Reply #38 on: April 20, 2019, 04:26:44 pm »
Offline Brutte
« Reply #39 on: April 20, 2019, 09:47:16 pm »
You can buy the Sn60Pb40 from tme
It is $16 + tax for 500g 0.7mm spool, >250 in stock.
Or you can get some from our local eBay but keep in mind not all those sellers ship abroad. The price is much lower but considering you just want tiny amount - use it as a price reference point.
« Last Edit: October 27, 2019, 09:35:07 am by Brutte »
Offline tooki
« Reply #40 on: April 21, 2019, 12:41:30 am »
Nope, can’t be shipped to Norway. See what happens when you change the country...
In Europe, leaded solder is no longer legal for sale to individuals.
Offline helius
« Reply #41 on: April 21, 2019, 04:58:34 am »
Norway isn't even part of the EU (although it has an arrangement that requires it to implement many of the same rules).
Offline Brutte
« Reply #42 on: April 21, 2019, 09:16:54 am »
:rant:
Ok, no Pb solder shipped to Norway. Interestingly when I select Poland or Germany, there are many of those Sn60Pb40 available...
Online stj
« Reply #43 on: April 21, 2019, 09:46:38 am »
it may say that, but german customs are bastards - they would probably steal it for not having a "CE" sticker on it.
they have built quite a reputation for stealing stuff for simply not having a sticker, mark or declaration on them.
Offline SilverSolder
« Reply #44 on: April 21, 2019, 02:36:35 pm »
Shipping is expensive unless you have high volume contracts in place with the carriers.
E.g. sending a package to Norway from the US will never cost less than $14.25 with the postal service, no matter how little you put in it (max 225g).
Offline tooki
« Reply #45 on: April 21, 2019, 03:27:59 pm »
Yep. Just like Switzerland. It’s not EU, but de facto most EU trade laws seem to apply anyway...
Offline OwO
  • Country: cn
  • RF Engineer.
« Reply #46 on: April 21, 2019, 03:59:31 pm »
ePacket from China to Norway starts at $3.5 for a 50g package and includes tracking.
Email: OwOwOwOwO123@outlook.com
Offline tooki
« Reply #47 on: April 21, 2019, 04:31:23 pm »
That’s fine, but of no use, since the entire point of this thread is this:
So, as I am tired with chinese solder, I'm looking to buy some brand-name solder. ...
« Reply #48 on: April 21, 2019, 05:38:44 pm »
When you pay for sending a package from America or Europe,  you are also paying tons of other costs that have nothing to do with the actual transportation of a package - including pensions for former postal workers, etc. etc.   This is how we like to do things -  load the prices of daily goods with all kinds of costs,  and we all get surprised when we see a Chinese product that isn't loaded with those costs!
In the long run, China will probably end up the same way.  "The price is what people are willing to pay"
  • Country: no
« Reply #49 on: April 21, 2019, 06:20:02 pm »
I ended my trying my luck on ebay, and I now have 100g of Stannol, and 100g of Cynel incoming, both 0.5mm and 64/40. Hopefully it is the real deal :)
