What version controller is this?
R11 is 4k7 on OLED V3.0, V3.1 (black pcb), near the EEPROM.
On V2.1, V2.12, V2.1S - R11 is a 0R jumper it has a trace to cut to use JBC. Near the GX connector. Like pic.
You open-circuit R11 (cut trace) for JBC, short-circuit it for T12.
The 245 thermocouple output is too much, it's almost two TC junctions worth, saturates the T12 clone controller's TC amp. You'd have to mod it.
For that reason, I don't know of anyone that has actually successfully used a clone T12 controller with JBC cartridge
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
