Author Topic: Old Iskra Unimer 2 :) (Metrawatt clone)  (Read 15092 times)
Offline SpiroTopic starter
  • Country: cs
« on: October 06, 2011, 06:17:27 pm »
Yeap. It is analog instrument with 1-1.5% accuracy. It can measure up to 5000V.
What CAT is that? Lion or tiger ;) Small burden voltage. It is at least 20 years old.
« Last Edit: October 07, 2011, 12:55:33 am by Spiro »
Offline Bored@Work
Re: Old Iskra Unimer 2 :)
« Reply #1 on: October 06, 2011, 06:48:39 pm »
That shows that badge engineering has a long tradition in the multimeter industry. Compare your Unimer 2 to the http://www.radiomuseum.org/r/goerz_unigor_3p3.html Especially have a look at the relays http://www.radiomuseum.org/images/radio/metrawatt_gmbh_vorm/unigor_3p_223315.jpg
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #2 on: October 06, 2011, 08:36:29 pm »
I'm not sure it is "badge engineering". If I remember well, Iskra was assembling   those meters under license from Goerz - Metrawatt.
I think they received "kits" of parts (see the Goerz name on the PCB and the German-made relay).
Before Yugoslavia "exploded" Iskra (that means, I believe, Spark) was a really big company that manufactured every kind of electronic and electrical equipment and parts, usually of good to very good quality. They were the only company manufacturing variacs in Europe (or st least the only one to make them available in Italy, in the 70s).
Regards
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Bored@Work
« Reply #3 on: October 06, 2011, 09:25:39 pm »
I was more thinking the other way around. Iskra building them, Goerz/Metrawatt (today Gossen) selling them under their name. It was common during those times that Western European companies used companies in Eastern Europe to build and assemble their goods. The WE companies were very careful to disguise the origin of their goods, because sales would go down if it turned out the goods were made by "communists". A little bit like today with stuff manufactured in Asia. So I would not be surprised if Iskra assembled the Unigor 3 or parts of it, too.
« Last Edit: October 06, 2011, 10:49:44 pm by BoredAtWork »
Offline tekfan
  • Country: si
« Reply #4 on: October 06, 2011, 09:42:27 pm »
I can't believe the circuit board actually says Goerz. Nice to see a backplate that you can actually read in nearly your own language. The Iskra plant was and still is located in the same city I go to school.
Yes Iskra does actually mean spark. A joke regarding the company name is often told. In the sence that their products often release sparks. ;D
Our school has piles of newer Iskra analog multimeters. The quality is not so good (they weren't meant for industrial use) but they all still work.
One can never have enough oscilloscopes.
  • Country: cs
« Reply #5 on: October 07, 2011, 12:54:14 am »
BoredAtWork you make my day. I HAVE METRAWATT. I am so happy  ;D
Ok, Metrawatt clone. But who cares. I HAVE METRAWATT CLONE!!!
1967? Is it possible that this instrument is that old?  It is still working,
but I have problem to find 1.5V battery used for resistance measuring.
It is nor AA. Must be some sort of lab precise bat. I am going to
put it in glass show case.
I HAVE METRAWATT clone!!!
Offline ciccio
« Reply #6 on: October 07, 2011, 07:55:18 am »
You must believe : please look at last photo of the original Spiro's post: there is GOERZ written on the PCB...
Regards
Offline david77
Re: Old Iskra Unimer 2 :) (Metrawatt clone)
« Reply #7 on: October 07, 2011, 10:00:54 am »
Very nice meter. I don't like putting stuff into glass cases just for show, I have the Unigor 6e and I still occasionally
use it.
  • Country: cs
« Reply #8 on: October 07, 2011, 12:37:00 pm »
David, how old is your Unigor 6e? I am very curious how old is this Iskra instrument.
It is spoil of war. This guy I bought instrument from took it from Lora navy base (near Split).
I bought it for 5 deutsche mark in '94-'95. Yeap, welcome to Balkan.
Interesting that you can buy Unigor 3p for just 30 euro.
http://mjs-electronics.se/images/Multi_ana/multi_ana.htm
There is lot of interesting old instruments on this site.
Offline zaoka
« Reply #9 on: October 07, 2011, 01:10:23 pm »
My first analog meter was Iskra Unimer 1 http://www.radiomuseum.org/r/iskra_unimer_1.html
It did not last long, I damaged it by switching ohms range to voltage..
Second was Iskra Unimer 31, it was new version of Unimer 1:
http://www.ouedkniss.com/annonces/electronique/154343/Photo1.jpg
I used this one for more than 5 years and gave it to my brother when I was leaving a country. It was built very well. I think this was Iskra design.
Not sure how many of you guys tried Triplett and Simpson, these are far more accurate and better quality than Iskra and Metrawatt analog meters.
Offline david77
« Reply #10 on: October 07, 2011, 03:30:07 pm »
I cannot tell how old my Unigor is, however I do have an old catalog of a long gone German eletronics supplier printed in
1976 and the meter is in there. If I remember correctly price was about 1100,- DM, or about 550,- EUR in todays money.
The 6e is a proper electronics meter, I still use it when I need to measure extremely low voltages/currents as it's smallest range
is 1mV/1µA full scale.
The Unimer 31 looks very much like the later analog Metrawatt meters
I disagree that BBC/Goerz/Metrawatt meters were of bad quality. You could (probably still can) find them in
most school physics labs in Germany and they were not treated very well there believe me.
I cannot comment on clones like the Iskras however.
Offline zaoka
« Reply #11 on: October 07, 2011, 09:36:13 pm »
Not sure for Unimer 31, as I remember all parts are made in Iskra, however, you never know.
Meters from 80s looks similar to Metrawatt:
