You're a hobbiest right, don't need specific composition and properties and such...
The RMA-223-UV flux gels on ebay etc in 10CC syringes, yeah, they work pretty good. Despite the label, they are absolutely not "Amtech" and are absolutely not "Made in USA", but that doesn't mean they don't work.
You can also get flux paste in tubs on ebay (or DX, or Ali or ...), just do not believe the weight on the label, it's not right by a long shot, assume you'll get maybe 75% at best, but the flux itself, well, it's flux, no problem, works like flux works. I note that dx.com are good about putting a more correct weight in the product title (but the label is still wrong).
Flux pens are on ebay too, coming from china don't believe "Kester" being written on the label for a moment, but probably it works just fine (disclaimer: I dont' use flux pens).
So in short, just grab a couple types of ebay for a couple bucks. It will work.
You could even , get some rosin off ebay (exactly same stuff used to "rosin up your bow"), grate, dissolve. The active ingredient in flux is rosin.
Do NOT get plumbers flux, that's acidic, no good for electronics.
And here's a couple of good old fashioned flux-offs :-)
