FWIW, Weller also uses flexible cables (silicone). But so should most, if not all, of the major brands (Weller, Hakko, Ersa, JBC, Metcal, ...).
Pricing will likely be an issue though, but used might be an alternative to consider (base unit + iron as a bare minimum to make it work).
