Author Topic: Hakko FX-888 in relations to voltage?  (Read 6187 times)
Offline Mint.Topic starter
  • Account is inactive now. Thanks everybody!
    • Personal Blog, Mint Electronics.
« on: November 06, 2011, 06:18:32 am »
Hey fellas, I was planning on buying a Hakko FX-888 Soldering iron for my beginner electronics lab, however the voltage that the iron uses is 120V (if bought off American amazon). How do I make the iron usable with Australian 240V? And/Or are there any stores around Melbourne which sell this station?
-Thanks in advance, Minty.
Personal Blog (Not Active Anymore), Mint Electronics:
http://mintelectronics.wordpress.com/
Offline amspire
Re: Hakko FX-888 in relations to voltage?
« Reply #1 on: November 06, 2011, 06:56:26 am »
You want to buy the 240V version.  It needs a different transformer.
It is available at places like http://www.mektronics.com.au, but the prices will hurt a bit if you have been looking at discounted 110V versions.
Probably about $176.
Richard.
Offline RCMR
« Reply #2 on: November 06, 2011, 08:30:15 am »
I live in NZ (230VAC) and I saved a bundle by purchasing the 110/120VAC Haako plus a suitable external step-down transformer.
Works perfectly and represents a significant saving over buying the 230V version of this iron.
Offline ElektroQuark
    • ElektroQuark
« Reply #3 on: November 06, 2011, 08:31:30 am »
Some people are buying the US version and changing the transformer at home. It is much cheappier than buy the 220V version.
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #4 on: November 07, 2011, 01:23:23 pm »
I detailed this change in one of my post-s, its simple as a cookie
Oh, the joy of sending various electronics to silicon heaven
    • ElektroQuark
« Reply #5 on: November 07, 2011, 04:33:21 pm »
Yes, I was too lazy to search for your post. Sorry.
  • Country: hr
    • HackLordSniper
« Reply #6 on: November 07, 2011, 04:41:30 pm »
No problem, im lazy sometimes too  :)
Offline ivan747
« Reply #7 on: November 08, 2011, 12:36:10 am »
I second the voltage converter transformer because it is handy for anything else that needs 120V. And remember, shipping heavy stuff internationally can be a PITA. Just my 2 cents.
  • Country: hr
    • HackLordSniper
« Reply #8 on: November 08, 2011, 06:43:13 am »
I usually avoid that by replacing transformer or modifying / replacing SMPS and dont bother with 110 V trannys
Offline RCMR
« Reply #9 on: November 08, 2011, 07:04:13 am »
The bonus for using a 110V tranny is that if (heaven forbid) the iron fails, you can still get it repaired/replaced under warranty.  Once you've opened it and changed the transformer, I suspect your warranty would be null and void.
  • Country: hr
    • HackLordSniper
« Reply #10 on: November 08, 2011, 08:42:34 am »
This is why you should test it an hour or two, if it works it will continue to do so. Anyway i bought my unit from USA and shipping back would be more expensive than any part. Secondly i glued the transformer with thermal epoxy, if you found a transformer in same size you could replace it and in case of fail just return the original one (nobody could know)
