Author Topic: Extremely cheap toys from china suggestions  (Read 2473 times)
Offline bd139Topic starter
« on: October 30, 2017, 09:15:51 pm »
Can anyone suggest some ridiculously cheap I.e. less than a couple of dollars / pounds things you can get from China, particularly interesting modules, components, boards, kits? The more stupid and dangerous the better.
I feel like ordering some stuff and forgetting about it for a few weeks and then getting interesting junk roulette deliveries :)
Online AndyC_772
Re: Extremely cheap toys from china suggestions
« Reply #1 on: October 30, 2017, 09:22:46 pm »
Why not just sit down and watch a Big Clive video until the feeling passes?
The following users thanked this post: Mr. Scram
Offline bsalai
« Reply #2 on: October 30, 2017, 09:26:52 pm »
The small high voltage module might fit your specs, especially if you fire it up  in the garage with some gas fumes.
Sent from my iPhone using Tapatalk
Brad, W2EK
« Reply #3 on: October 30, 2017, 09:57:58 pm »
Because I want to experience the joy of shite not through the portal of youtube :)
Ordered. 400KV version.  :-+
I've got a 40KV probe so it'll be interesting to see if it actually gets anywhere near that potential. I doubt it'll get anywhere near that. The entire thing would break down before it got anywhere near even 40KV.
Offline Mr. Scram
  • Display aficionado
« Reply #4 on: October 30, 2017, 10:13:18 pm »
In lieu of an actual static electricity gun, I'm wondering if one of those could be used to create an ESD testing device. Maybe it's a bit too much?
Offline bsalai
« Reply #5 on: October 30, 2017, 10:16:33 pm »
I don’t have a way to measure the voltage but it will arc across 1/8 - 1/4 inch, maybe a bit more. That doesn’t seem anything like 40 KV to me
Brad, W2EK
Offline Mr. Scram
« Reply #6 on: October 30, 2017, 10:21:11 pm »
I was just looking at what voltages are needed for what arc. I guess that could be a fairly crude method of establishing the actual voltages involved.
Offline bsalai
« Reply #7 on: October 30, 2017, 10:26:42 pm »
We used to rely on that to select plate capacitors for high voltage RF amplifiers
Brad, W2EK
Offline Mr. Scram
« Reply #8 on: October 30, 2017, 10:29:22 pm »
Can you tell us about that process?
Offline Cyberdragon
« Reply #9 on: October 30, 2017, 10:32:53 pm »
There are actual static electricity cannons. Oddly enough they are marked as levitating foil toys, despite the fact they pack a hell of a punch and can fry electronics. I'll try and find some, but I don't know what they are called.
EDIT:
https://www.amazon.com/s/?ie=UTF8&keywords=fun+fly+stick+magic+levitation+wand&tag=googhydr-20&index=aps&hvadid=178102005990&hvpos=1t1&hvnetw=g&hvrand=337217266583948475&hvpone=&hvptwo=&hvqmt=b&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9008093&hvtargid=kwd-10862990755&ref=pd_sl_hrgcwrlh5_b
The things with the foil or foam balls and rings that hover in front of the stick by static.
« Last Edit: October 30, 2017, 10:41:01 pm by Cyberdragon »
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline bsalai
« Reply #10 on: October 30, 2017, 11:49:44 pm »
We would estimate the breakdown voltage of variable capacitors by measuring the distance between adjacent plates. I keep thinking 10 thousand volts per inch, but I am not sure that is correct.
Wikipedia says
Although air is normally an excellent insulator, when stressed by a sufficiently high voltage (an electric field strength of about 3 x 106 V/m or 3 kV/mm), air can begin to break down,
So I guess it’s pretty close.
Brad, W2EK
Offline ralphrmartin
    • Me
« Reply #11 on: October 31, 2017, 06:39:54 pm »
There are plenty of Tesla coil kits for under a fiver.
