We used to rely on that to select plate capacitors for high voltage RF amplifiers
Sent from my iPhone using Tapatalk
Can you tell us about that process?
We would estimate the breakdown voltage of variable capacitors by measuring the distance between adjacent plates. I keep thinking 10 thousand volts per inch, but I am not sure that is correct.
Wikipedia says
Although air is normally an excellent insulator, when stressed by a sufficiently high voltage (an electric field strength of about 3 x 106 V/m or 3 kV/mm), air can begin to break down,
So I guess it’s pretty close.
