Author Topic: Ever taken an Intel Atom CPU apart?  (Read 7484 times)
Offline MadsaabyTopic starter
  • Beware ! MCUs will take over the world!
    • Ec-Projects
« on: September 03, 2012, 12:18:01 am »
Hey Guys
I had a dead motherboard laying around which I was about to throw away.
So I thought it would be interesting to take a look inside the CPU itself.
I heated the puppy up with a hot-air gun, and lifted the CPU of the MB. And carefully broke of the fanout board from the core itself while applying heat with a blowtorch.
I ground the CPU on 1800c sandpaper with a glass plate underneath for a short time, to get a nice surface as of pic 1.
I discovered that the copper interconnect layers, and dye itself was so ridiculously thin that it was impossible to control the grinding this way (pic 2 and 3).
So I took a tiny peace of sandpaper, and bend it to get a sharp point which I could use to grind down more where it needed to. I finally, at the very last layer, managed to get (almost) the whole dye visible.
It looks very fascinating if you haven't seen the guts of a CPU before.
(The pictures are not the best, but bear with me, it's not easy to focus on such a thing, while getting the right angle of both (a very bright!) light, and camera at the same time ;D WHILE KEEPING THE CORRECT TONGUE ANGLE !)
Hope someone find this interesting, at least I had fun with it ;)
- Mads
Offline ablacon64
  • Country: br
Re: Ever taken an Intel Atom CPU apart?
« Reply #1 on: September 03, 2012, 02:30:17 am »
It's amazing! Thanks for the post!
« Reply #2 on: September 03, 2012, 04:57:02 am »
I must photograph the IBM core I have decapped then.........
Offline amyk
« Reply #3 on: September 03, 2012, 08:25:18 am »
The different colours you see are due to diffraction effects; at 45nm feature sizes, many times smaller than the wavelength of light, even a light microscope won't let you see the individual transistors and interconnects.
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: September 03, 2012, 04:45:34 pm »
Guess you'll need one of these  8)
Offline codeboy2k
« Reply #5 on: September 03, 2012, 08:16:15 pm »
My wife wants one of those.
I told her I'll build her one, I have started drawing up plans using sections of flanged drain
pipe that I plan to weld together. I'm planning it so it can be torn down, maintained etc.. in
manageable sections.  I hope to use a gun from an old black and white TV or O'scope, don't
know which is best yet.  I have know idea what to expect from it, I'm still planning and researching.
I do hope to make one for less than a $million lol...
    • Ec-Projects
« Reply #6 on: September 03, 2012, 10:33:12 pm »
Heh, is that an Electron Microscope ? :O
Offline krenzo
« Reply #7 on: September 03, 2012, 10:49:14 pm »
If you want to see more high resolution images of the insides of chips, look here.
Offline T4P
  • Country: sg
    • T4P
« Reply #8 on: September 04, 2012, 02:43:03 am »
It is  8)
Very expensive these things  :P
« Reply #9 on: September 04, 2012, 04:46:17 am »
Best guns are not from a CRT, but a car headlamp that you break open. You need a very robust heater, preferably a short one that you can run at 5A or so.
Offline amyk
« Reply #10 on: September 04, 2012, 08:38:36 am »
Someone has actually made a SEM for quite a bit less than that:
http://benkrasnow.blogspot.ca/2011/03/diy-scanning-electron-microscope_26.html
...although its resolution isn't high enough to be used for chip photography.
    • Ec-Projects
« Reply #11 on: September 04, 2012, 10:12:54 pm »
It is  8)
Now that's not fair  :o  :D  :D
Hehe, I don't think I should even think about the price of such a thing..
    • Ec-Projects
« Reply #12 on: September 04, 2012, 11:49:33 pm »
Yea, you should :) Post a link here if you do, could be interesting to see.. :D
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #13 on: September 05, 2012, 03:07:37 am »
It is  8)
I believe Jeri Ellsworth has an electron microscope. Still in boxes, but she does have one.
Offline T4P
  • Country: sg
    • T4P
« Reply #14 on: September 05, 2012, 03:46:29 am »
Too expensive for me... just googled that picture  :D :D
She's a great engineer in most aspects, even knows to bake her own transistors!
I'm not surprised though that she has one
Offline arekm
« Last Edit: September 05, 2012, 08:09:18 pm by arekm »
Offline Wim_L
« Reply #16 on: September 06, 2012, 03:11:30 pm »
Except that it looks like a transmission electron microscope, and you'd usually want a scanning electron microscope (working using backscatter and/or secondary emission) for looking at chips. Unless you can prepare extremely thin sections of those chips, that is.
Offline T4P
  • Country: sg
    • T4P
« Reply #17 on: September 06, 2012, 05:08:47 pm »
It's just an rough image, not intended to be 100% accurate   :o
