I've been trying to assemble a couple of switching power supplies based on the 34063 that Dave talks about in blog #110, and was seeing a really peculiar oscillating voltage out of the circuit. After spending some time tracking it down, I found that the source was actually the bench power supply I was using to drive the switcher - my BK Precision 1665. Let's see if I can figure out how to post an image from my scope.
Input 2 wasn't connected at the time and can be ignored, but as you can see I get these odd oscillating pulses on the output. Also note that this was measured with DC-coupled probe. I haven't yet figured out what the difference is between AC and DC coupled or when one should use one over the other.
Anyway these crazy pulses of over 1V peak-to-peak are a bit alarming, even if they're not the source of the problem I'm having in my project. This is my one and only bench power supply - should I be concerned about this? I've used it for a number of projects, so I'm guessing it's just something I need to be aware of, like the slow ramp-up when the supply is switched on. If this behavior is likely to cause problems, what sort of symptoms am I likely to see?
(FWIW, the power controller I'm building is for a camcorder, and I'm 90% sure the problem is insufficient power when the camera is switched on, and the "glitch" above is unrelated)
