Author Topic: X-Soldering pro not working whith origijal JBC tips  (Read 1522 times)
Offline dmendesfTopic starter
  • Country: br
« on: September 03, 2021, 04:32:57 am »
I got a X-Soldering pro from aliexpress and a few original JBC tips (240 and 210) but both doesn't work. When the probe rests it says "power down mode" and shows the ambient temperture (probably wrong). When I pick it up it gives an error and does`t heat up. Any hints?
Offline thm_w
  • Non-expert
Re: X-Soldering pro not working whith origijal JBC tips
« Reply #1 on: September 03, 2021, 09:44:49 pm »
Did it come with any tips, do those work?
What error is displayed?
  • Country: br
« Reply #2 on: January 16, 2022, 12:37:05 pm »
Reviving my (own) old topic. I bought a X-Soldering pro at Aliexpress and asked a friend to buy original JBC tips in USA. When both arrived I tested the station and it didn't work: probes where recognized while the handle was at the base
1381858-0
but as soon as I take them out it tries to heat up but fails:
1381864-1
If I return the handle to the base it doesn't return to work:
1381870-2
Only way to make the station recognize the probes again is power cycling. The most incredible part is that a few days later I tried again and the station worked wonderfully.... and now it stopped working again, same syntoms. Any ideas? I think it may be noise injected from ground pin... will disconnect it and see wha happens.
Offline thm_w
  • Non-expert
« Reply #3 on: January 17, 2022, 09:32:02 pm »
Do you have a properly earth grounded outlet?
  • Country: br
« Reply #4 on: January 17, 2022, 10:31:12 pm »
Yes I do have a proper eath ground. Lifted it and nothing changed. I did more tests today and think the problem is different: I used another station to heat the 245 and 210 tips and the X-Soldering pro showed the increasing temperatures. Seems it's not driving power thru the tips to heat them and shows the error sign when the integrator error (from PD/ PID controller) saturates.
