Hello, for those interested in running a Hakko 888 110V on a 240V line without replacing the transformer this is how I did it:
- remove the ZNR
- put a 8µF 400V X class cap in series with the primary of the transformer
- put a 100Kohms bleed resistor across the cap
It's working fine for me. Little power wasted and the cap can go in the housing on top of the transformer.
Modifications at your own risks obviously.
