Author Topic: ECM 395 - Teardown - and Tech Questions  (Read 2859 times)
Offline AcousticBruceTopic starter
« on: April 09, 2013, 02:35:36 pm »
I bought this item for 5 bucks at an live action. I figured the transformer and caps would be worth 5 if it didn't work. Well I figured maybe I can sell it. It seems they still sell for 500-700 bucks refreshed. Maybe I can get a couple hundred. Either way I am happy to just tear down and learn and keep parts if all else fails.
So I am after a few things.
1) I want to know if my Fluke 83-III is good enough to test this equipment.
2) I would like to know what groups of various component systems are called on this thing (power supply, capacitor bank ext.)
3) One of the MOSFET's have some weird colors on the solder and I was wondering if it looks like a problem to you.
4) Maybe we can walk through and trouble shoot this for fun. If it takes 6 months it is worth it to me.
Tests that I did....
1) Set the machine on various voltages... such as 100V, 500V and 1kV.
2) Used fluke and set on Max mode so it shows the max voltage.
3) The most voltage I got was 340V on the LV mode (500V setting on machine)
4) On the HV section of the machine I am not sure I got anything. One time it said OL on the Fluke but I couldn't get it to repeat.
So as for my question 1 about the Fluke. Is this Fluke good enough to catch a quick voltage such as one like this machine does? Is there another setting I should know about?
Ok and now for the pictures.
Front Panel
Mainboard
Capacitor Bank
Power Supply
N-Channel MOSFET
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: ECM 395 - Teardown - and Tech Questions
« Reply #1 on: April 09, 2013, 02:46:53 pm »
This is a pulse power supply - I have a later version.
It charges the caps up to the required voltage, then discharges on demand.
Be careful - it can deliver a dangerous shock!    :scared:
The hi/lo switches configures the caps in series or parallel.
Definitely not to be poked around with, Fluke or otherwise on the 3kv range.
Day Job: Mostly LEDs
« Reply #2 on: April 10, 2013, 05:16:55 am »
Cool I was wondering if they were ever in series.
My fluke is rated for 1kv. I only set the dial to 1kv on the ECM and it showed like 40v on the Fluke on discharge. So something must be going on.
Did you notice the mosfet Q9? It looks rather weird near the solder joints. What do you think?
