Author Topic: Zhongdi products  (Read 9381 times)
Offline MiniTopic starter
  • Country: ee
Zhongdi products
« on: December 22, 2018, 12:36:52 pm »
Hello, i have found many topics about Yihua, but can't find any about zhongdi. My local seller is selling mostly zhongdi products. How about their quality, reliability? Looking for 2in1 soldering station with hot air. Budget is about 150 bucks. I found a lot of topics about Yihua and they seem to be good enough, but still would like to hear something about zhongdi. Thanks for answering.
« Last Edit: December 22, 2018, 10:38:47 pm by Mini »
Online wraper
  • Country: lv
Re: Dzhongdi products
« Reply #1 on: December 22, 2018, 12:56:18 pm »
Crap. You'd be better with hakko knockoff. And it's zhongdi BTW. Yihua is among the worst hakko knockoffs. And I would suggest avoiding 2 in 1. Also at local sellers zhongdi is usually sold at ridiculously high prices.
« Last Edit: December 22, 2018, 12:58:03 pm by wraper »
Offline Bud
« Reply #2 on: December 22, 2018, 01:35:28 pm »
Dzhongdi is a knockoff of Zhongdi  :-DD
  • Country: ee
Re: Zhongdi products
« Reply #3 on: December 22, 2018, 10:43:38 pm »
I know everything is crap for 150 bucks. I could get only decent soldering station for this money, but i want both. I don't need professional equipment, just doing some hobby soldering. If Yihua is bad then what's better in your opinion(for same amount of money)? I have soldered with one zhongdi station and it wasn't too bad. My local seller is selling zhongdi ZD-8922 for 75 euros which isn't bad(ebay guys selling it for 100+).
Online wraper
  • Country: lv
« Reply #4 on: December 22, 2018, 11:04:27 pm »
This particular one has hakko knockoff iron.  So should be OK, likely better than yihua. Hot air is weird. Apparently handpiece has internal fan but then why there is a hose going to the station, not just a cable?  :-//
Most of zhongdi soldering stations have solomon knockoff irons which are outdated.
« Last Edit: December 22, 2018, 11:06:29 pm by wraper »
Online wraper
  • Country: lv
« Reply #5 on: December 22, 2018, 11:08:57 pm »
Hot air is a bit weak, only 300W, 24L/min.
Offline coppice
« Reply #7 on: December 22, 2018, 11:23:44 pm »
Why do you want a hot air gun? They really aren't very useful for most engineers. I've always had high quality ones around me in the lab, but I've rarely used one.
Online wraper
  • Country: lv
« Reply #8 on: December 22, 2018, 11:34:19 pm »
You said something really stupid. It's essential tool these days.
Offline coppice
« Reply #9 on: December 22, 2018, 11:46:26 pm »
So, Mr Genius, what do you need a hot air gun for, and why is it most engineers hardly ever use one?
Online wraper
  • Country: lv
« Reply #10 on: December 23, 2018, 12:14:26 am »
For everything. Need to solder QFN, you're fucked without hot air. Want to replace any SMD part with multiple pins, it's a pain without hot air. Building your own circuits, you're like a crippled person without hot air or reflow oven, unless you are making complete beginner level through hole stuff. Sort of can do many things without hot air but it will take much more time, effort and risk.
Those engineers either don't do any real work on physical circuits or are outdated by 2 decades.
« Last Edit: December 23, 2018, 12:18:53 am by wraper »
Offline coppice
« Reply #11 on: December 23, 2018, 12:33:47 am »
For everything.
Everything? Really?
I've never used a hot air gun for a QFN. They are a real pain to work with using a hot air gun.
Why would anyone use a hot air gun for that? There are numerous methods for swapping out most big SMD parts with a soldering iron. Dave has videos on some of them.
Building your own circuits, you're like a crippled person without hot air or reflow oven, unless you are making complete beginner level through hole stuff. Sort of can do many things but it will take much more time, effort and risk.
Most professional prototypes are hand soldered. Reflow is more of a production process. I assume from the tone of the OP's post that they are a hobbyist. I don't think they are looking for production solutions.
I think its you who are out of date. In the 80s most people thought hot air was essential for everything SMD, and most labs had a number of high end (mostly Hakko) hot air tools. By the early 2000s most of those tools had disappeared. Look at Hakko's catalogue. They don't even make most of these tools any more, as the market isn't there.
If you are fixing things with large BGAs, you might think a hot air tool is essential. Its still a very problematic tool, though, as its so damned hard to get the package and the board heated to the same temperature and cooled correctly, so you don't leave huge expansion related stresses in the structure, leading to early failure.
Online wraper
  • Country: lv
« Reply #12 on: December 23, 2018, 12:50:27 am »
Everything? Really?
I use hot air way more often than soldering iron when repairing something. When I'm building something my own, I use vapor phase oven, otherwise would use hot air.
Then please explain how you soldered center pad?
Because it's much easier and faster. Chip quick is expensive and difficult to use, a lot of risk of damage. Also if you just use solder wick to remove it only once, without tinning and wicking again, you will get brittle solder joints after that. I'd use something like that only there is a high risk damaging something nearby by heating.
It's way easier to just use syringe with solder paste and hot air. Not to say soldering with iron only is not really applicable to QFN, LGA and most power mosfets.
:palm: |O Market is way bigger than ever before. And all of those tools by traditional companies are still made.
Look yourself. FR-810B, FR-811, 851, FR-702
Offline coppice
« Reply #13 on: December 23, 2018, 12:55:00 am »
Exactly. That's all they have left now. In the early 90s they made a long list of hot air tools.
Online wraper
  • Country: lv
« Reply #14 on: December 23, 2018, 12:59:49 am »
What list? something outdated like 852? Low end is completely dominated by Chinese companies these days.
EDIT: Also about long list of hakko hot air models in the past, I suspect your memory is playing tricks with you? If it's something with a stand and preheater to solder BGA, nowadays IR stations are used more often instead.
EDIT2: https://www.hakko.com/english/support/discontinued/  The only hot air that got no modern replacement  (sort of, read further) is HAKKO 854. And there is no wonder why. It was basically just a  combo of hot air gun on a stand + small preheater like 853 for a ton of money. All of those things are available from hakko separately in several variations to be used together with a hot air station. For a ridiculous price though https://www.hakkousa.com/products/accessories/rework-fixtures.html
Market is certainly "shrinking", thus a ton of different stations became available https://www.amazon.com/gp/search/ref=sr_pg_1?rh=n%3A228013%2Cn%3A%21468240%2Cn%3A8106310011%2Cn%3A553006%2Cn%3A13837391%2Cp_n_feature_keywords_browse-bin%3A3415502011&ie=UTF8&qid=1545539326&ajr=3
« Last Edit: December 23, 2018, 04:30:24 am by wraper »
Offline OZ1LQB
« Reply #15 on: December 23, 2018, 12:40:57 pm »
Hi..
I have soldering station and desoldering station and hot air station
from Zhongdi and they do what i want them to do.
i even gave my weller desoldring station away.
would i buy Zhongdi products again,YES for sure.
Claus in denmark
  • Country: ee
« Reply #16 on: December 23, 2018, 01:38:17 pm »
Hi OZ1LQB, what station are you using?
  • Country: ee
« Reply #17 on: December 23, 2018, 01:47:26 pm »
How do you know it has hakko knockoff iron? It uses its own tips. Not sure will hakko ones fit with it. Yihua is hakko knockoff and uses 900m series tips and hakko original heating element(thats why i think Yihua might be better). Not sure about zhongdi hot air, but there should be pump inside not fan inside hot air tool.
Online wraper
  • Country: lv
« Reply #18 on: December 23, 2018, 02:14:18 pm »
It looks the same and tips look the same as well. I'm 95% sure they have the same dimensions. Even if dimensions are a bit different, it's still a knockoff because it copies design.
Handle has a round space for placing a blower fan there. Just like any other cheap hot air station. If there is no fan inside, it would be really strange to use such handle.
  • Country: ee
« Reply #19 on: December 23, 2018, 03:44:04 pm »
Could be or they use same housing for all stations. Anyways i checked Yihua and same thing, like you said all cheap clones use this. Yihua costs way more though(995d version). I checked your link from ebay not sure about that quality neither, just another clone. And yes problably hakko tips will fit it. I think i might give it a try. Do you know where i can find original hakko tips? I don't trust those chinese sellers from ebay.
  • Country: ee
« Reply #20 on: December 23, 2018, 10:03:55 pm »
Im still in between zd-8922(75 euros) and yihua 995d+(115 euros) or 992da(115 euros), can buy 992da+(155 euros) as well. 992da has diaphragm for sure. Maybe someone still can make up my mind since this discussion haven't helped me much so far.
Online wraper
  • Country: lv
« Reply #21 on: December 23, 2018, 10:15:48 pm »
I said what would be optimal for $150-$160. It would beat in performance and quality everything you listed here. And that fume extraction 992 has is a joke. Not only it obstructs soldering, it just blows non filtered fumes out through hot air gun.
« Last Edit: December 23, 2018, 10:18:55 pm by wraper »
Offline stj
« Reply #22 on: December 23, 2018, 11:04:37 pm »
i wont tell you what to buy, but buy seperate units.
combined ones are harder to repair and will cost more to replace eventually.
Online all_repair
« Reply #23 on: December 23, 2018, 11:40:10 pm »
My Hakko 808 Clone hotair finally gave way after almost 20 year.  The plastic hand piece has melted and could not hold the hot chamber tight.  If you are going to use a lot, get seperate units for the iron and hotair.  Thing does spoil, integrated unit shall be not as easy to replace.  Thing also improve, so seperate units allow to get individual upgrade as you see fit.  But space is a premium on any workbench, integrated unit has its place.  Instead of getting a replacement handler.  I seached Taobao for what is the selling well (wisdom of the crowd) .  858 is the best seller, but I ended up getting a 959 with a spare heating element, which cost a bit more than 858 but has auto-handler detection and also a few temperature setting memory.
Offline OZ1LQB
« Reply #24 on: December 24, 2018, 10:50:20 am »
hej..
Mini mine are
Desoldering=ZD915
Soldering=ZD981
Hotair=ZD939L
they are getting old(5-10years) but still working fine
Claus in denmark
