The first release is an Android utility application which can be used to dump the complete content of SLIX2 tags:
https://github.com/free-dmo/free-dmo-tag-dumpYou just start the app, hold it near the paper roll to scan it and it will show the complete dump.
It also will create a text file per dump in the "Downloads" folder.
It comes with full source code but also contains a pre compiled APK for "lazy" people (BUT: You really should NEVER EVER download APKs from somewhere and install them to your main Android device... Go the extra mile and check the source then compile it yourself!).
@ALL: It would be nice if you could use the app to scan some of your rolls (doesn't matter if consumed or fresh). Please copy/paste the content of the text file and post them here.
The difference of the raw dump compared to the output of other NFC apps is that it contains extra information like the Originality Signature from SLIX2 tags (which we need for a complete emulation).
JS
Attached are my 2 rolls. One is the small roll which comes with the printer the other one is SKU "S0722430" (54mm x 101mm | 2 1/8 x 4 inch)
EDIT: One more roll attached.
Anybody else please?
