Author Topic: Dymo 550 Thermal Printer DRM Hacking  (Read 66563 times)
Offline sleemanj
  • Professional tightwad.
Re: Dymo 550 Thermal Printer DRM Hacking
« Reply #75 on: March 12, 2022, 10:41:12 pm »
FYI, amazon said on twitter they would do something about it and a few hours later a ton of old reviews have been removed.
Probably only from that specific listing you had, where as this was the first one I got when googling for "amazon labelwriter 550" and has 7.4k reviews dating back years.
https://www.amazon.com/DYMO-Label-Printer-LabelWriter-Thermal/dp/B08TLRL392/ref=cm_cr_arp_d_product_top?ie=UTF8&th=1
Offline GopherT
« Reply #76 on: March 13, 2022, 04:43:47 am »
Looks like someone was fired over this...
Demo is looking for a new Product Manager/Brand Manager.
https://careers.newellbrands.com/us/en/job/2200802/Product-Manager-Brand-Manager-DYMO
Offline ygi
« Reply #77 on: March 13, 2022, 04:34:54 pm »
If someone got fired/quit it had to be because they were the one person in the company opposed to that stupid cash grab. No corporate drone's ever been fired for being too greedy on behalf of their employer.
Offline DynoDrmBeGone
« Reply #78 on: March 13, 2022, 07:05:31 pm »
Just noticed something and hope it might help in figuring a way to defeat this insane DRM protection...
When I'm printing labels from my MacBook pro M1 it tends to print an empty lable after the original print... However if u unplug the USB cable from my Mac directly after the first lable is done printing, the empty lable isn't generated, but even better if I cancel the print job without the USB cable and reconnect the printer the lable count isn't decremented so you can print without decreasing or incrementing the nfc counter and it will still accept to print the next lable afterwards... I now have an empty roll wit 32 prints left
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #79 on: March 13, 2022, 10:11:13 pm »
If there is a significant delay between it reading and writing the RFID tag, maybe a possible approach is to jam the signal with an external (modulated) 13.56MHz source to block the write.
Day Job: Mostly LEDs
« Reply #80 on: March 13, 2022, 10:41:06 pm »
Wouldn't it theoretically be possible to create a write locked NFC tag, with the expected Dymo data on to it? Than the printer can do it's roll type detection, thinks it's already used for some prints so it doesn't have to do any initialisation (if it even does that on the first print) and simple can't decremented the counter?
Offline apelly
  • Probe
« Reply #81 on: March 13, 2022, 11:01:37 pm »
From that page:
Join us and benefit from:
    4Ts Values: Truth, Transparency, Teamwork, Trust
    Corporate Citizenship Philosophies – environmentally sustainable and socially sensitive business practices.
The following users thanked this post: EEVblog
Offline js_12345678_55AA
  • Country: ht
« Reply #82 on: March 14, 2022, 11:55:19 am »
Looks like all those Arduino libraries do not support I2C slave very well  :(
I tried ESP32, STM32 (we need a 3.3V MCU).
Next best thing would be to use native STM32 for emulation (stm32 blue pill boards seem to be available everywhere, even boards with cloned STM32 should work)
JS
BTW: The mentioned "CY8CKIT" Infineon IC / board is expensive and ICs are not available as far as I can see. Any particular reason why this was suggested?
Easy PDK programmer and more: https://free-pdk.github.io
Offline mistial_dev
« Reply #83 on: March 15, 2022, 09:08:09 pm »
The cy8ckit-059 has apparently had a price increase.
They used to be $10, which was a great value for the chips you get with it.  Looks like infineon has hiked things a bit.
https://www.reddit.com/r/PSoC/comments/360r4p/10_for_cy8ckit059_has_cypress_psoc_5lp_target/
They still have some really nice i2c support, though, and it is very easy to work with.
https://www.infineon.com/dgdl/Infineon-Component_I2C_V3.30-Software+Module+Datasheets-v03_05-EN.pdf?fileId=8ac78c8c7d0d8da4017d0e9599661ff4
The biggest advantage with cypress is that as long as you are doing something that's officially supported, the libraries/tools/etc. you need are all first party, and tend to be fairly top notch.
The disadvantage is when you want to go beyond what's officially supported.  The tooling stops helping you and starts fighting you.
« Last Edit: March 15, 2022, 09:09:51 pm by mistial_dev »
  • Country: ht
« Reply #84 on: March 16, 2022, 03:14:15 pm »
I decided to use a STM32F103 since they are (still) available for reasonable prices from various sources. Anything like a "blue pill" will work.
And..... IT IS WORKING!  8) 8) 8)
Full emulation of the reader IC + tag as a standard CubeMX project.
Whenever the roll is changed or the printer enters power down mode the counter is "REFRESHED" :P
Next step... I additionally interface the original reader so change of paper types is easy (just hold a tag of the paper type you want to use to the side of the printer and the emulator will "LEARN" it).
JS
The following users thanked this post: EEVblog, thm_w, voltsandjolts, dl6lr
Offline mistial_dev
« Reply #85 on: March 16, 2022, 09:15:03 pm »
That’s smarter than what I was planning.
If you are planning on releasing, I’ll stop working on mine.
« Reply #86 on: March 16, 2022, 11:43:11 pm »
...but that assumes you've already bought some of the original expensive labels...
Offline mistial_dev
« Reply #87 on: March 17, 2022, 12:22:35 am »
Or have cloned the tag to a card.
Offline Bud
« Reply #88 on: March 17, 2022, 02:33:29 am »
Please do not, we need diversity.  ::)
Offline EEVblogTopic starter
« Reply #89 on: March 17, 2022, 04:27:13 am »
 :clap:
A DIP switch maybe?
Most people stick with the same roll in the sme machine all the time, and there are mostly only a coulple of major label sizes people use.
  • Country: ht
« Reply #90 on: March 17, 2022, 01:25:06 pm »
Thanks for the suggestions...
The emulation contains "learned" labels already, and if you use it like I do (multiple rolls per day all of the same type) then this is just enough.
Switching between rolls can be done using either another original roll (which is then learned) or by using a simple of the shelf NDEF Tag where you just write the SKU of the roll (e.g. "S0722430") inside (like you do with business card information, any phone can do this nowadays).
So by presenting either an original roll the complete data is learned, or by presenting a normal RFID NDEF tag with the SKU inside to choose from the pre installed tags is enough to switch between rolls.
This makes it possible to modify the printer once and then no need to open again in order to switch roll types.
Meanwhile I also created a small Android app which can be used to dump the complete SLIX2 tag (including the "signature" data).
I will setup a github project in the next few days with all the sources.
(As soon as github outtage is over: https://www.githubstatus.com )
On the other hand I learned about a very beautiful (and available) NXP IC today. A friend suggested to have a look at the NHS3100 IC.
https://www.nxp.com/docs/en/data-sheet/NHS3100.pdf
Ignore the "temperature logging" in the title... and have a look at chapter "8.10 RFID/NFC communication unit"
This IC is a CortexM0 which can speak the correct NFC protocol...
This makes it possible to completely emulate a SLIX2 tag with a "magic counter":
The IC is (including inflated pricing) $4:
https://www.digikey.com/en/products/detail/nxp-usa-inc/NHS3100-A1Z/6578221
A completely working development board (which should be usable as magic tag) is availbale for $60 (Will pay itself after using only 4 off-brand rolls 8))
https://www.digikey.com/en/products/detail/nxp-usa-inc/NHS3100TEMODBUL/6578223
And I really like the idea to fight NXP with NXP  :-DD
Looks like the UID is fixed so this can not be used  :-[
JS
« Last Edit: March 17, 2022, 02:50:23 pm by js_12345678_55AA »
  • Country: ht
« Reply #91 on: March 17, 2022, 06:18:05 pm »
The first release is an Android utility application which can be used to dump the complete content of SLIX2 tags:
https://github.com/free-dmo/free-dmo-tag-dump
You just start the app, hold it near the paper roll to scan it and it will show the complete dump.
It also will create a text file per dump in the "Downloads" folder.
It comes with full source code but also contains a pre compiled APK for "lazy" people (BUT: You really should NEVER EVER download APKs from somewhere and install them to your main Android device... Go the extra mile and check the source then compile it yourself!).
@ALL: It would be nice if you could use the app to scan some of your rolls (doesn't matter if consumed or fresh). Please copy/paste the content of the text file and post them here.
The difference of the raw dump compared to the output of other NFC apps is that it contains extra information like the Originality Signature from SLIX2 tags (which we need for a complete emulation).
JS
Attached are my 2 rolls. One is the small roll which comes with the printer the other one is SKU "S0722430" (54mm x 101mm |  2 1/8 x 4 inch)
EDIT: One more roll attached.
Anybody else please?
« Last Edit: March 22, 2022, 10:58:37 am by js_12345678_55AA »
The following users thanked this post: mistial_dev
  • Country: ht
« Reply #92 on: March 28, 2022, 01:56:16 pm »
It's done...
https://github.com/free-dmo/free-dmo-stm32
- full emulation for "endless" printing
- optional pass through of original RFID tag data (only the counter will be emulated)
JS
The following users thanked this post: EEVblog, bitwelder, thm_w, voltsandjolts, tooki, 2N3055
Offline mistial_dev
« Reply #93 on: March 29, 2022, 03:10:48 am »
Plenty of things to hack out there.  I can do something else :)
Offline mistial_dev
« Reply #94 on: March 29, 2022, 03:28:43 am »
Here ya go.  4x6 inch, or 104x159mm.  Standard shipping size.
The following users thanked this post: js_12345678_55AA
Offline SkullKill
Offline tooki
« Reply #96 on: March 31, 2022, 10:52:15 am »
#FREEDMO GETS RID OF DYMO LABEL PRINTER DRM
https://hackaday.com/2022/03/30/freedmo-gets-rid-of-dymo-label-printer-drm/
Yyyyyeah, we know, since the developer of that is a forum member and documented his progress in this thread.
Offline SaltyDog
« Reply #97 on: March 31, 2022, 12:52:45 pm »
Can someone please dump a 1x1" tag? I will dump mine, when it comes in, and if no one posts.
« Reply #98 on: April 03, 2022, 12:26:36 pm »
Louis did a follow-up, and I agree. The hack, whilst  :clap: worthy isn't going to make a difference I'm afraid.
Those that have the motiviation/ability to do the hardware hack are those who have the motivation never to use Dymo again for this. Almost all business customers will just continue to buy the genuine Dymo labels.
We need to hit Dymo hard now or every other manufacturer will see that they succeeded and they will try the same thing. We do this buy having an active anti-Dymo campaign and refusing to use their products and buying their competitors (I recommend Zebra). Keeping on top of the fake Amazon reviews and the like etc and help grow the new organic 1 star reviews. Eventually it has to hit Dymo where it hurts.
The following users thanked this post: BillyD
« Reply #99 on: April 03, 2022, 12:29:19 pm »
And for those that want an alternative to the Dymo label software, and have support for countless printers including the old Dymos, I've been talking to the author of this software:
https://label.live/
He's also close to releasing his own printer as well.
