if there is a ventilator shortage, I wonder if a assembly can be made for a regular hand drill (which can switch rotation direction) so simple tubing can be used to make a respirator unit? can it be done with common vinyl tubing?4
see the post under for ideas on manufacturing. I don't think a 3d printer is required for this pump, since its basically planar and uses a hose. More advanced pumps could be made with a 3d printer, but I think if this works, you could make it with wood, coping saw and some sand paper by hand, without power even.
Keep in mind even 1 day of run time would be enough, pumps are typically designed to last alot longer then 24 hours before they chew through the hose, so there might be alot of room to breath as far as reducing complexity goes.
Also, its very hygienic, because the hose could simply be burned after use in a barrel.
If necessary, a car could be used to turn the axle and a burst disk fitted to protect patients.
