Author Topic: Alpin 12V car mini compressor teardown  (Read 4311 times)
Offline HydrawerkTopic starter
« on: April 27, 2013, 02:35:07 pm »
Now this compressor is assembled again and it works fine. It's a cheap chinese product bought in Bauhaus shop in 2012.
Photos: https://plus.google.com/photos/106264218831814439783/albums/5814895676942736977
In action
« Last Edit: April 27, 2013, 05:49:18 pm by Hydrawerk »
Re: Alpin 12V car mini compressor teardown
« Reply #1 on: May 10, 2014, 09:12:32 pm »
Sorry for answering late.
> what is the power (current) of the engine. This is not visible on any of the pictures
According to the manual it consumes 12 Amps at 12 Volts. I did not measure it, but I believe this figure. Please see this: https://plus.google.com/photos/106264218831814439783/albums/5814895676942736977/5814896464339355346?pid=5814896464339355346&oid=106264218831814439783
> also from the picture not clear if the valves can be manipulated so that it becomes a vacuum pump
I did not dismantle the valves, but I do not think it is possible.
-> how much did you spend/where did you buy it?
It cost less than 1000 CZK at Bauhaus hobbymarket.
