I have been looking at this one for $139.80. I don't know how good they are versus some of the name brand stuff but for the features and accessories the price point seems very attractive.
Skip it. Get a good, top quality iron, and an inexpensive hot air station (or better yet IMHO, a good quality used one).
Also, separates will allow you to use one to fix the other when it breaks. Particularly useful if you go Chinese.
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
All I really need is a decent iron with tips that don't dissolve with even light use. I figure if I'm going to invest money, I might as well get some added features.
If you look between the least expensive and most expensive units from name brand companies, even for just soldering stations, you'll see there are differences. Including additional features.
Look for things like better stands (
setback feature when the iron is placed in is the biggest, but may also contain upgrades such as a tip cubby and multiple cleaning options), better heating technology (i.e. cartridges vs. simple tips butted to/slid over a heating element permanently fixed in the handle), ... types of things that improve it's performance, make it cheaper to operate (setback will extend tip life for example), and is much easier, comfortable, and faster for the user to perform joints (and time translates into $$$ for a business).
So in the case of Hakko, you can go with the inexpensive FX-888D, or step up to say the FX-951. Both make proper joints, but the latter will have features and better ease of use than the cheaper model. And in the case of these two stations, the costs are quite reasonable for NEW here in the US (under $100 for an FX-888D, ~$267 for a new FX-951). Tips are cheap too at ~$5 per for the FX-888D, and ~$10 for common profile cartridges for the FX-951 (most common profile cartridge types tend to be closer to ~$30 per, such as those from both Weller and JBC for example).
Buy from authorized retailers to avoid fakes IMHO (possible to find legitimate products elsewhere, but it's always a risk).
Also avoid poor quality 3rd party tips (authorized retailer aspect is crucial here due to the fake tips floating around). They will reduce an iron's performance (poor fit = poor thermal transfer), nor are they cost effective due to more frequent replacement (thin plating = wear out faster).
what is a tip typically plated with? nickel? if so, i can try that too.
Tip construction is typically done as follows:
1. Make the tip out of copper.
2. Plate entire bit with iron (~135 - 150 um)
3. Plate any surface you don't want wetted with solder with nickel.
4. Repeat #3 using chromium.
Keep in mind, that molten tin will rapidly dissolve most metals, including copper. So a protective layer must be applied that won’t dissolve so rapidly in tin, and iron is one of the few metals that can actually withstand tin for any reasonable amount of time (and is also cost effective).
