Author Topic: Best Tweezers etc  (Read 27712 times)
Offline pidcon
  • Country: my
Re: Best Tweezers etc
« Reply #50 on: July 23, 2020, 10:19:47 am »
I vote for Ideal-Tek too. It's really good and worthwhile, but expensive.
As for the Ideal-Tek action, it is smoother and it will put less stress on the hands if you're using it for long hours.
For cheap tweezers, I quite like the Pro's Kit tweezers.
Offline MarkMLl
« Reply #51 on: July 23, 2020, 12:06:09 pm »
Whenever I look for "pro's kit", eBay et al. insist on presenting the clothing categories...
MarkMLl
Offline calin
« Reply #52 on: July 24, 2020, 03:14:53 am »
If you don't want to break the bank and want some nice good ones try on amazon - search for: Aven 18475USA.  30$ for a set of 6 nice enough tweezers ... you decide
Offline mahi
« Reply #53 on: September 17, 2023, 11:46:19 am »
(I know this is an old topic but I don't think my post warrants a new one and this topic comes up in many searches on tweezers)
I was looking for reverse-action tweezers. For my daily tweezers I use quality ones from Ideal-tek and Vomm but I did not think reverse-action tweezers to be important enough to go for the top brands. So, I purchased a few no-name reverse-action tweezers from Amazon but these turned out to be a major disappointment. Weak clamping force, imprecise and blunt tips made them rather frustrating to use.
After seeing pictures by member eliocor of Lindström TL SM100-SA and TL 7X-SA reverse-action tweezers, I really wanted to have some of these. But, I was not looking forward to paying Lindström prices and even if I wanted, I couldn't find the tweezers for sale. They appear to be out of stock everywhere with no indication of lead time.
In the meantime I learned that Ideal-tek is the OEM of Lindström, but I couldn't find the Ideal-tek version of the TL SM100-SA.
Then by coincidence I found a picture of a pair of tweezers that looked virtually identical to the Lindström TL SM100-SA: The Wetec SM100.SA. I had never heard of Wetec but apparently its the house brand or affiliate of Dönges, a large German retailer (of which I had not heard either). When inspecting other Wetec tweezers I discovered that many look identical to the Ideal-tek/Lindström offerings. Wetec also states "Swiss made". My confidence started to grow that these Wetec tweezers were also made by Ideal-tek. Best of all is that the prices are considerably cheaper than Ideal-tek and Lindström. So, I decided to order a few including the SM108.SA which I already had from Ideal-tek for comparison (I purchased from the Dönges eBay shop as shipping was much lower but that may differ from country to country).
I really didn't need another one, but last week I scored a lightly used Lindström TL SM108-SA from eBay which would make the comparison complete.
Pictures of the Wetec SM108.SA, Ideal-tek SM108.SA and Lindström TL SM108-SA:
The Wetec tweezers come with the same ribbed silicone tube tip protection as Ideal-tek and Lindström.
At first glance all three look identical. They have the same satin (sand blasted?) finish and rounded edges.
Wetec left, Ideal-tek middle, Lindström right. A close-up of the tips when closed. The tips were held closed for the picture by using a header but I didn't do a good job with the Ideal-tek. I did not notice until after making the pictures that it was not fully closed. In reality it is just as good as the Wetec.
Wetec left, Ideal-tek middle, Lindström right. Holding 0603 capacitors.
Judging by these pictures the Wetec and Ideal-tek look virtually identical but the Lindström seems to have a slightly more accurate tip shape. Keep in mind these tweezers are all hand-made so some variance is normal. There is no difference in how they "feel" when handling small components.
Anyway, this confirms the Wetec tweezers are genuine rebranded Ideal-tek tweezers. They are still relatively expensive, but cheaper than Ideal-tek and a lot cheaper than Lindström. So they might be a good option for them who want to up their game but not pay full prices.
Here are a few pictures of the Wetec 7X.SA, 2AX.SA, 3X.SA and SM100.SA reverse-action tweezers:
From left to right: Wetec 7X.SA, 2AX.SA, 3X.SA and SM100.SA.
From left to right: Wetec 3X.SA holding 0603 capacitor, SM100.SA holding 30AWG patch wire, 7X.SA holding 0603 capacitor and 2AX.SA holding 3528 LED.
Disclaimer: I have no affiliation with Wetec or Dönges, I only compared tweezers I was interested in so other models may come from different manufacturers, and it is possible Wetec gets "second grade" or rejects from Ideal-tek but from my small sample set they seem to be just as good as the Ideal-tek ones.
« Last Edit: September 17, 2023, 11:49:12 am by mahi »
The following users thanked this post: bingo600, chickenHeadKnob, helius, tooki, spostma, KaneTW, JimKnopf, MarkMLl
Offline eliocor
    • rhodiatoce
« Reply #54 on: September 17, 2023, 03:03:08 pm »
Offline Microdoser
« Reply #55 on: October 03, 2023, 05:17:46 pm »
I quite like the ceramic tipped ones for their complete lack of ability to ever get magnetised, also you can replace the tips if anythign happens to them. Part of the removable tip bonus is you can slightly adjust the tips to get a perfect tip fit.
https://m.media-amazon.com/images/I/516v6RwkgdL._AC_.jpg
https://www.amazon.co.uk/gp/product/B002F9MQOC
