Author Topic: Hakko FX-888D  (Read 6334 times)
Offline TRa757Topic starter
Hakko FX-888D
« on: September 04, 2013, 10:16:41 pm »
Got a new iron today and was surprised to see the digital readout and no big dial.  I thought I was getting the one with a dial.  Should I send it back and get the one with a dial or is this one okie dookie?
Thanks,
Offline Isamun
  • Country: no
Re: Hakko FX-888D
« Reply #1 on: September 04, 2013, 10:35:48 pm »
I have one of these and I don't complain about the buttons. Seems like people who are used to the dial are complaining though. Anyway, the "analog" version is discontinued, so I would think it could be problematic to get a swap.
If this is your first station and you don't mind the buttons, there's no reason to worry. It is every bit as capable and has some extra features (presets, real time readout, password ++)
Tip: get a thermal pad like this one, it makes it a hell of a lot easier to swap hot tips =)
http://www.all-spec.com/products/B2300.html
http://www.ebay.com/itm/Hakko-B2300-ESD-Safe-Heat-Resistance-Pad-for-the-FM2026-/200958203145?pt=LH_DefaultDomain_0&hash=item2eca0ad509
Offline wizzy
Re: Hakko FX-888D
« Reply #2 on: September 04, 2013, 11:10:30 pm »
If it troubles you and you live near Sydney i would be willing to swap. :P
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Hakko FX-888D
« Reply #3 on: September 04, 2013, 11:20:07 pm »
The dial model (which is what I have) has been discontinued, as far as I understand. I wanted the dial model so I got one before it was too late.  :)
I have heard of people screwing up the calibration by pressing the buttons before they knew what they were doing, so be careful.
Offline ivan747
Re: Hakko FX-888D
« Reply #4 on: September 05, 2013, 07:49:30 pm »
And to make it fair, you would only swap the base, not the iron or the holder.
Offline Napalm2002
Hakko FX-888D
« Reply #5 on: October 09, 2013, 01:48:36 am »
I have one. Its my first station. And I love it!
Sent from my iPhone using Tapatalk - now Free
Offline geo_leeman
    • Professional Website/Blog
Re: Hakko FX-888D
« Reply #6 on: October 09, 2013, 12:20:45 pm »
While being able to twist a knob quickly is nice, once you get the hang of the interface it's very easy.  I don't mind it and really like the real time temperature display.  I do wish there was a more simple up/down button set though, but presets really do all the work.
Offline netdudeuk
Re: Hakko FX-888D
« Reply #7 on: October 11, 2013, 10:04:27 pm »
Is it true that you cannot get BCM/CM bits like this for the 888 ?
http://www.hakko.com/english/tip_selection/type_bcm_cm.html
Offline Greyersting
  • Electronics noob
Re: Hakko FX-888D
« Reply #8 on: October 11, 2013, 10:40:53 pm »
Why would you change the tip while it was hot?
Contact-
Greyersting2@gmail.com
Offline Monkeh
Re: Hakko FX-888D
« Reply #9 on: October 11, 2013, 10:47:54 pm »
So you don't have to wait for it to cool?
Offline twjdeboer
Re: Hakko FX-888D
« Reply #10 on: October 12, 2013, 09:09:23 pm »
That's what the extra D stands for. The original was the FX-888
If only I could get one in The Netherlands for a fair price...
Offline Isamun
  • Country: no
Re: Hakko FX-888D
« Reply #11 on: October 13, 2013, 06:53:53 pm »
I found it tiring to dick around with pliers to swap the tips while hot. The thermal pad makes it easier, but I wouldnt go back to this after using the FM-2027 iron with its proper hotswapping.
Ive used the 900M series tips with this iron, and that works a treat. There are a lot more to choose from in this series.
edit: Link
« Last Edit: October 13, 2013, 07:02:46 pm by Isamun »
Offline BravoV
  • +++ ATH1
Re: Hakko FX-888D
« Reply #12 on: October 13, 2013, 06:59:11 pm »
If its easy and cheap to find the "fake" iron, here what I did with the problem of swapping tips when they're hot -> Here
