I accidentally plugged in my Hakko FR-301 Desoldering Tool, rated 120V, into a 220V outlet.
I turned it on and I heard a "click", then I immediately turned it off. I then plugged it in to a 120V transformer to test it, and at least the pump is working fine. It started heating up for a bit, but then it stopped heating altogether.
I opened it up for a visual inspection and there is no visible damage on the PCB or anywhere.
According to
this post, all I would need is a
heating element.
I'm looking for opinions and thoughts regarding this being the part needed, and help understanding what exactly fails in this heating element, can the part itself be repaired?
Thank you.
