Author Topic: Reverse engineering (HW/SW) of HP printers - DeskJet f2180  (Read 7485 times)
Offline ronenkTopic starter
« on: June 13, 2014, 10:02:06 pm »
Hello everybody,
Over the years I have amassed a large collection of HP printer main boards from small to large and always wanted to see what kind of hardware they use and maybe even re-purpose them
as a network attached machine or maybe even as a DEV board.
So I've dug around and found a board from this printer HP DESKJET f2180 which is an All-in-one old printer vintage ~2006.
The problem with every HP product is the markings on almost all of the chips are HP proprietary numbers.
For example the main SoC is a Marvell one but the codes on it are 2CR6-0001 1825-0126
which off-course are not the SoCs real numbers.
The SPI flash on the board was an OKI part with the same weird numbers, but I've figured it out and dumped it, it's just a
8Mbit SPI flash.
Luckily the board has a UART connection as well but not much info came from it(just stuck a serial cable on the ports and watched what happens)
So here is my progress,
SOC - Have no Idea, MFG Marvell - ARM?MIPS?POWERPC? don't know.
FLASH - SPI 8Mbit OKI.
TI Part - A micro ? for USB handling ?
I2C - 24c32an 4KB eeprom for what ?
RAM - 32Mbit
And other probably useless to me stuff.
What do I have:
I have the raw firmware dump from the SPI chip, it has some strings in it (the bootloader is unencrypted and unpacked) but the most of it is packed.
BINWALK tells me nothing about it at all.
Attached is the firmware file.
And here is the UART output
It shows some useful stuff like where is the bootloader ending and code beginning
But I've tried OnlineDissasamble, IDA, HEX editor and I only get trash from those can't figure out the architecture how to decode the bootloader, how to uncompress the data.
And this is where I need some help/guidance, any body knows how to read the bootloader? what architecture is the SoC ?
any info, suggestions will be helpful.
PS. typing 'uart' in the console shows empty table, tried typing other stuff, does nothing.
Thank you.
Offline amyk
Re: Reverse engineering (HW/SW) of HP printers - DeskJet f2180
« Reply #1 on: June 14, 2014, 02:57:53 pm »
- I see the version ID (05090701) at the beginning of the file, and at 2228 is D    C21CAB8, followed by the table of firmware parts:
dc269328 00c578b8 00000028
dc2691c0 00c578e0 00000168
So that tells us the processor is big-endian.
Next, note that near the beginning there is a regular pattern of every 4 bytes' high nybble being E, this is almost certainly ARM code since that is the encoding of the "always" predicate present on most instructions. Indeed the first 2 instructions (reset vectors?) disassemble to
LDR PC, =0xC0001C
LDR PC, =0xC00014
suggesting that the flash image is mapped into memory at C00000 (there's a few other ARM SoCs out there that have a similar mapping - search around.) Now you can start disassembling from there - it switches into thumb mode not long after doing something with the MMU, and then...
ROM:00C005FA  LDR     R6, =a0123456789abcd
ROM:00C005FC  LDR     R1, [SP,#0x18]
ROM:00C005FE  LSR     R3, R1, #0x1C
ROM:00C00600  LDRB    R0, [R6,R3]
ROM:00C00602  BL      sub_0_C010A6
ROM:00C00606  LDR     R1, [SP,#0x18]
ROM:00C00608  LSL     R1, R1, #4
ROM:00C0060A  STR     R1, [SP,#0x18]
ROM:00C0060C  LDR     R1, [SP]
ROM:00C0060E  ADD     R1, #1
ROM:00C00610  STR     R1, [SP]
ROM:00C00612  CMP     R1, #8
ROM:00C00614  BLT     loc_0_C005FA
ROM:00C00616  ADR     R7, asc_0_C00694 ; "\n\r"
ROM:00C00618  ADD     R0, R7, #0
ROM:00C0061A  BL      sub_0_C010B8
ROM:00C0061E  ADR     R0, aBootBootId ; "[Boot] Boot ID:  "
ROM:00C00620  BL      sub_0_C010B8
ROM:00C00624  BL      sub_0_C003C4
ROM:00C00628  ADD     R0, #0xC
ROM:00C0062A  BL      sub_0_C010B8
ROM:00C0062E  ADD     R0, R7, #0
ROM:00C00630  BL      sub_0_C010B8
ROM:00C00634  BL      sub_0_C0099C
ROM:00C00638  STR     R0, [SP,#4]
ROM:00C0063A  ADD     R5, R0, #0
ROM:00C0063C  ADD     R4, R0, #0
ROM:00C0063E  ADR     R0, aBootNvmCode0x ; "[Boot] NVM Code: 0x"
I'll let you trace the rest... also you may notice interesting strings at 5d560, suggesting that the compression is LZ with indicator bytes and that this an ARM9. It also identifies the "OS" it uses.
Good luck!
« Reply #2 on: June 19, 2014, 10:03:13 pm »
amyk,
Thanks for the explanation and the help! I appreciate it.
I'm trying to find where is the switch to THUMB occurs,
; Processor       : ARMB
ROM:00C00000 ; Target assembler: Generic assembler for ARM
ROM:00C00000 ; Byte sex        : Big endian
ROM:00C00000
ROM:00C00000 ; ===========================================================================
ROM:00C00000
ROM:00C00000 ; Segment type: Pure code
ROM:00C00000                 AREA ROM, CODE, READWRITE, ALIGN=0
ROM:00C00000                 ; ORG 0xC00000
ROM:00C00000                 CODE32
ROM:00C00000                 LDR     PC, =loc_C0001C
ROM:00C00004 ; ---------------------------------------------------------------------------
ROM:00C00004                 LDR     PC, =loc_C00014
ROM:00C00008                 DCD 0x5090701
ROM:00C0000C                 DCB 0x63, 0x75, 0x72, 0x6C, 0x79, 0, 0, 0
ROM:00C00014 ; ---------------------------------------------------------------------------
ROM:00C00014
ROM:00C00014 loc_C00014                              ; CODE XREF: ROM:00C00004j
ROM:00C00014                                         ; DATA XREF: ROM:00C00004o ...
ROM:00C00014                 MOV     SP, #1
ROM:00C00018                 B       loc_C00208
ROM:00C0001C ; ---------------------------------------------------------------------------
ROM:00C0001C
ROM:00C0001C loc_C0001C                              ; CODE XREF: ROM:00C00000j
ROM:00C0001C                                         ; DATA XREF: ROM:00C00000o ...
ROM:00C0001C                 MOV     SP, #0
ROM:00C00020                 MOV     R1, #0xD3
ROM:00C00024                 MSR     CPSR_cxsf, R1
ROM:00C00028                 MRC     p15, 0, R0,c1,c0
ROM:00C0002C                 MOV     R1, #0x80
ROM:00C00030                 ORR     R0, R1, R0
ROM:00C00034                 MCR     p15, 0, R0,c1,c0
ROM:00C00038                 MOV     R0, R1
ROM:00C0003C                 MOV     R1, R0
ROM:00C00040                 LDR     R2, =0x20813500
ROM:00C00044                 MOV     R0, #0
ROM:00C00048                 STRH    R0, [R2,#0xA]
ROM:00C0004C                 MOV     R0, 0x212C
ROM:00C00054                 STRH    R0, [R2,#6]
ROM:00C00058                 MOV     R0, 0x5060
ROM:00C00060                 STRH    R0, [R2]
ROM:00C00064                 MOV     R0, 0xCDA
ROM:00C0006C                 STRH    R0, [R2,#2]
ROM:00C00070                 MOV     R0, 0x4E1
ROM:00C00078                 STRH    R0, [R2,#4]
ROM:00C0007C                 MOV     R0, #3
ROM:00C00080                 STRH    R0, [R2,#8]
ROM:00C00084                 MOV     R0, #1
ROM:00C00088                 STRH    R0, [R2,#0xC]
ROM:00C0008C                 NOP
ROM:00C00090                 NOP
ROM:00C00094                 NOP
ROM:00C00098                 NOP
ROM:00C0009C                 NOP
ROM:00C000A0                 NOP
ROM:00C000A4                 NOP
ROM:00C000A8                 NOP
ROM:00C000AC                 MOV     R3, #1
ROM:00C000B0
ROM:00C000B0 loc_C000B0                              ; CODE XREF: ROM:00C000B8j
ROM:00C000B0                 LDRH    R0, [R2,#0xC]
ROM:00C000B4                 ANDS    R0, R0, R3
ROM:00C000B8                 BNE     loc_C000B0
ROM:00C000BC                 MOV     R0, #8
ROM:00C000C0                 STRH    R0, [R2,#0xA]
ROM:00C000C4                 MOV     R3, #3
ROM:00C000C8
ROM:00C000C8 loc_C000C8                              ; CODE XREF: ROM:00C000D4j
ROM:00C000C8                                         ; ROM:00C000E4j ...
ROM:00C000C8                 LDRH    R0, [R2,#0xE]
ROM:00C000CC                 ANDS    R0, R0, R3
ROM:00C000D0                 CMP     R3, R0
ROM:00C000D4                 BNE     loc_C000C8
ROM:00C000D8                 LDRH    R0, [R2,#0xE]
ROM:00C000DC                 AND     R0, R0, R3
ROM:00C000E0                 CMP     R3, R0
ROM:00C000E4                 BNE     loc_C000C8
ROM:00C000E8                 LDRH    R0, [R2,#0xE]
ROM:00C000EC                 AND     R0, R0, R3
ROM:00C000F0                 CMP     R3, R0
ROM:00C000F4                 BNE     loc_C000C8
ROM:00C000F8                 NOP
ROM:00C000FC                 NOP
ROM:00C00100                 NOP
ROM:00C00104                 NOP
ROM:00C00108                 MOV     R0, #0xA
ROM:00C0010C                 STRH    R0, [R2,#0xA]
ROM:00C00110                 MOV     R7, 0x20814400
ROM:00C00118                 LDRH    R1, [R7,#4]
ROM:00C0011C                 ORR     R1, R1, #1
ROM:00C00120                 STRH    R1, [R7,#4]
ROM:00C00124                 MOV     R1, 0x404
ROM:00C0012C                 STRH    R1, [R7]
ROM:00C00130                 MOV     R1, #0x15
ROM:00C00134                 STRH    R1, [R7,#2]
ROM:00C00138                 MOV     R1, 0x827
ROM:00C00140                 STRH    R1, [R7,#6]
ROM:00C00144                 MOV     R1, 0x311
ROM:00C0014C                 STRH    R1, [R7,#8]
ROM:00C00150                 MOV     R1, #5
ROM:00C00154                 STRH    R1, [R7,#0xA]
ROM:00C00158                 MOV     R1, #0x66
ROM:00C0015C                 STRH    R1, [R7,#0xC]
ROM:00C00160                 MOV     R1, 0x3FF
ROM:00C00168                 STRH    R1, [R7,#0xE]
ROM:00C0016C                 MOV     R1, #0x14
ROM:00C00170                 STRH    R1, [R7,#0x12]
ROM:00C00174                 MOV     R1, #0x60
ROM:00C00178                 STRH    R1, [R7,#0x1E]
ROM:00C0017C                 MOV     R1, #0xF
ROM:00C00180                 STRH    R1, [R7,#0x1C]
ROM:00C00184                 ADD     R6, R7, #0x32
ROM:00C00188                 ADD     R5, R7, #0x14
ROM:00C0018C                 MOV     R4, #8
ROM:00C00190                 BLX     loc_C00314
ROM:00C00194                 ADD     R5, R7, #0x1A
ROM:00C00198                 MOV     R4, #2
ROM:00C0019C                 BLX     loc_C00314
ROM:00C001A0                 ADD     R5, R7, #0x16
ROM:00C001A4                 MOV     R4, #1
ROM:00C001A8                 BLX     loc_C00314
ROM:00C001AC                 LDR     R6, =0x2081FE00
ROM:00C001B0                 MOV     R1, #0x30
ROM:00C001B4                 STRH    R1, [R6,#0x1E]
ROM:00C001B8                 MOV     R0, #0xC8
ROM:00C001BC                 BLX     loc_C0034C
ROM:00C001C0                 MOV     R1, #0
ROM:00C001C4                 STRH    R1, [R7,#0x22]
ROM:00C001C8                 MOV     R0, #1
ROM:00C001CC                 BLX     loc_C0034C
ROM:00C001D0                 MOV     R1, 0x4002
ROM:00C001D8                 STRH    R1, [R7,#0x10]
ROM:00C001DC                 MOV     R0, #1
ROM:00C001E0                 BLX     loc_C0034C
ROM:00C001E4                 MOV     R1, 0x121
ROM:00C001EC                 STRH    R1, [R7,#0x10]
ROM:00C001F0                 MOV     R0, #4
ROM:00C001F4                 BLX     loc_C0034C
ROM:00C001F8                 MOV     R1, #0x21
ROM:00C001FC                 STRH    R1, [R7,#0x10]
ROM:00C00200                 MOV     R0, #0x2D
ROM:00C00204                 BLX     loc_C0034C
ROM:00C00208
ROM:00C00208 loc_C00208                              ; CODE XREF: ROM:00C00018j
ROM:00C00208                 MRC     p15, 0, R0,c1,c0
ROM:00C0020C                 MOV     R1, 0x1005
ROM:00C00214                 BIC     R0, R0, R1
ROM:00C00218                 MCR     p15, 0, R0,c1,c0
ROM:00C0021C                 MOV     R1, #0x3F
ROM:00C00220                 MCR     p15, 0, R1,c6,c0
ROM:00C00224                 MOV     R1, #0x33
ROM:00C00228                 MCR     p15, 0, R1,c6,c1
ROM:00C0022C                 MOV     R1, 0xDC000031
ROM:00C00234                 MCR     p15, 0, R1,c6,c2
ROM:00C00238                 MOV     R1, 0xFC000031
ROM:00C00240                 MCR     p15, 0, R1,c6,c3
ROM:00C00244                 MOV     R1, 0xFE000031
ROM:00C0024C                 MCR     p15, 0, R1,c6,c4
ROM:00C00250                 LDR     R1, =0x2081001F
ROM:00C00254                 MCR     p15, 0, R1,c6,c5
ROM:00C00258                 MOV     R1, 0x20000023
ROM:00C00260                 MCR     p15, 0, R1,c6,c6
ROM:00C00264                 MOV     R1, #0x40000037
ROM:00C00268                 MCR     p15, 0, R1,c6,c7
ROM:00C0026C                 MOV     R1, #0x1E
ROM:00C00270                 MCR     p15, 0, R1,c2,c0, 1
ROM:00C00274                 MOV     R1, #0xE
ROM:00C00278                 MCR     p15, 0, R1,c2,c0
ROM:00C0027C                 MOV     R1, #0xFC
ROM:00C00280                 MCR     p15, 0, R1,c3,c0
ROM:00C00284                 MOV     R1, 0xFFFF
ROM:00C0028C                 MCR     p15, 0, R1,c5,c0, 1
ROM:00C00290                 MCR     p15, 0, R1,c5,c0
ROM:00C00294                 MRC     p15, 0, R0,c1,c0
ROM:00C00298                 MOV     R1, 0x1005
ROM:00C002A0                 ORR     R0, R1, R0
ROM:00C002A4                 MCR     p15, 0, R0,c1,c0
ROM:00C002A8                 MOV     R0, #8
ROM:00C002AC                 LDR     R0, [R0]
ROM:00C002B0                 MOV     R1, SP
ROM:00C002B4                 MRC     p15, 0, R2,c1,c0
ROM:00C002B8                 ORR     R2, R2, #0x40000
ROM:00C002BC                 MCR     p15, 0, R2,c1,c0
ROM:00C002C0                 LDR     SP, =0xFC0009D0
ROM:00C002C4                 LDR     PC, =(loc_C005B8+1)
all seems like native ARM, including the jump to C005B8
but after that it looks all scrambled.
LDRLTB  R11, [R0,#0x87]!
ROM:00C005BC                 ANDLS   R9, R6, R5,LSL#2
ROM:00C005C0                 MRRCMI  p9, 5, R4,R10,c11
ROM:00C005C4                 SMLABBLS R3, R12, R2, R4
ROM:00C005C8                 ANDLE   R12, R5, #0x700
ROM:00C005CC                 LDRNVB  PC, [PC,R4,ROR#29]!
ROM:00C005D0                 STMLSDA R3, {R2,R7,R9,LR}
ROM:00C005D4                 MOVLES  R4, 0xFFFFEA3F
ROM:00C005D8                 LDMMIDB R7, {R2,R8,R12,PC}^
ROM:00C005DC                 ADDMI   SP, SP, #0x50000000
ROM:00C005E0                 STCGT   p7, c15, [R7,#-0x3FC]
ROM:00C005E4                 CDP2    p8, 0xE, c9,c5,c4
ROM:00C005E8                 ADDMI   SP, R5, #0xE4000003
ROM:00C005EC                 ANDNV   PC, R0, R1,LSL#27
ROM:00C005F0                 SUBGES  PC, R2, R0
ROM:00C005F4                 STC2L   p2, c2, [R1]!
ROM:00C005F8                 ANDLS   R4, R0, #0x550
ROM:00C005FC                 STMLSDB R6, {R0,R1,R3,R8-R11}
ROM:00C00600                 LDCPLL  p0, c15, [R0]
ROM:00C00604                 LDC2L   p9, c9, [R0,#-0x18]
ROM:00C00608                 TSTEQ   R9, R6,LSL#2
which makes me believe it happens after the jump.
Is my assumption correct.
Still trying to pinpoint what type of Marvell SoC this is, most of the ones I've found are the modern ones.
88F5182  looks close, but seems unlikely that it's used (too overpowered for this application)
Offline amyk
« Reply #3 on: June 20, 2014, 12:10:56 pm »
Yes, the code after that is Thumb (and there's the occasionalNotice the target of that jump at c002c4 - it's putting c005b9 into r15 but ARM instructions must be aligned to multiples of 4 (and Thumb, multiples of 2). From this:
In T and T2 variants of ARMv5 and above:
in ARM state, a load to r15 causes a change to Thumb state if bit[0] of the value loaded is 1
in Thumb state, a load to r15 causes a change to ARM state if bit[0] of the value loaded is 0.
« Reply #4 on: June 20, 2014, 03:03:43 pm »
Small update,
Just used IDA and put xScale processor and all the bootloader decompiled just fine.
So not it's just sifting trough the code.
and find JTAG maybe.
So it's  xScale processor maybe pxa260 or pxa270.
Offline amyk
« Reply #5 on: June 21, 2014, 12:54:16 pm »
It's definitely not a PXA2xx, but a custom chip Marvell designed for HP. There may be similarities, however.
