From the beginning, the station had temperature overshooting, on the display it was very short, so it couldn't be real and now I decided to check it out. It was not good what I found - the temperature was not read correctly at all, for 300 C on the display it varies from 10-15 centigrade. Another issue - it has a temperature compensation for the desired temperature, but it is correct only for that point, if you change it, it goes out of the set point - nightmare??? Same with the hot-air gun.
When I bought it everything looked nice, I couldn't expect somebody to start selling completely useless devices.
So, Stay away from CXG
