Author Topic: Crocodile clip insulation  (Read 966 times)
Offline nukieTopic starter
« on: October 16, 2019, 03:57:06 am »
I have an issue with the mini crocodile clip PVC insulation sleeve going hard, it makes it very stiff to operate the jaws. I am not sure why they not as pliable anymore maybe the plastic storage case for storage is causing some reaction to the sleeves.
Most branded crocodile clips sell sleeves seperately, I can replace but this is alot of work I will have to cut and resolder the wires.
So I am thinking of painting or dipin the body in some sort of thick coating maybe epoxy? Is there anything permanent I can use to coat the body? Most of my projects are low voltage under 24v. Any suggestions for black and red coating?
Offline MosherIV
Re: Crocodile clip insulation
« Reply #1 on: October 16, 2019, 07:08:52 am »
Get silicone rubber based croc clip covers, PVC will degrade over time.
Get them from reputable sources, ie not ebay or amazon.
Keep them away from natural rubber and sunlight.
