Author Topic: Crimping 3 or 4 wires together  (Read 1585 times)
Offline ezalysTopic starter
« on: June 04, 2019, 01:57:04 pm »
Hey all,
I’m looking for the most reliable, milspec, aerospace, NASA approved way to join 3-5 stranded 24 AWG wires together where there’s likely to be a lot of vibration. I understand that solder has a nasty habit of wicking up the strands, and the point at which the unwetted wire meets the wetted wire can be brittle and unreliable. I also understand that solder isn’t a great mechanical joint. I’m therefore looking for a good crimp I can use to splice several wires together. Any recommendations? Also, if I’m wrong about solder joint reliability, I’d be interested too!
Thanks!
Offline Neilm
Re: Crimping 3 or 4 wires together
« Reply #1 on: June 04, 2019, 06:37:46 pm »
Given the vibration requirements in that sort of application, I doubt you will find a single crimp that could go that. I have seen crimps that look like a Y and will join three wires together. You could use several of them if you can find one that will crimp the metal wire and hold the insulation as a support as well.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline No.Mad
« Reply #2 on: June 04, 2019, 07:29:49 pm »
Hi ezalys,
answer for your question is in IPC 620A standard. It covers all topics regarding harness making, looming, splicing and crimping.
What is my favourite is soldered splice: simply strip 10 - 12mm of a wire insulation, place it together tightly but don't twist them. To hold them together you should use single strand copper wire to make a braid like in the picture here: https://cdn.instructables.com/FN1/KYZT/JNIRDS9X/FN1KYZTJNIRDS9X.LARGE.jpg?auto=webp&width=599&crop=3:2
Apply flux, solder wires and then clean with with proper solvent. After that go for final touch - give it some snugly and warm heatshrink :D
I'm attaching also two pages from IPC standard so you could have a better understanding of criteria. Have fun and practice bruv!
Regards
Offline timelessbeing
« Reply #3 on: June 04, 2019, 07:43:16 pm »
Are you launching a satellite?
Online Kjelt
« Reply #4 on: June 04, 2019, 07:54:41 pm »
Download NASA-STD-8739.4A – 2016-06-30
Page 70 and further.
Some of those solutions need special ferrules $0,30 a piece but min order 1000 pcs or such madness.
Just use a standard copper tinned Ferule that matches the best of your need and use that.
Offline coppercone2
« Reply #5 on: June 05, 2019, 05:35:53 am »
we need to cut costs for the non existing company for no reason at all :-\
just give them a twist and wrap it in electrical tape!1!1
