Author Topic: Compression F connector  (Read 2144 times)
Offline jeroentTopic starter
« on: June 02, 2013, 06:53:55 am »
I am wondering how the shield of the cable makes good contact with the shield of a compression F connector. With most compression connectors a piece of plastic is pressed into the connector to keep the cable secured, but I can't figure out how the actual contact is made.
Offline Nermash
Re: Compression F connector
« Reply #1 on: June 02, 2013, 07:57:49 am »
Inside the connector there is a metal tube that wedges itself between jacket and shield when you push the cable in.
Offline amyk
« Reply #2 on: June 02, 2013, 08:26:20 am »
