Author Topic: A look inside the Agilent MSO6034A Scope  (Read 5389 times)
    • Mike's Electric Stuff
« on: January 27, 2012, 08:47:22 am »
Day Job: Mostly LEDs
Offline BravoV
  • +++ ATH1
Re: A look inside the Agilent MSO6034A Scope
« Reply #1 on: January 27, 2012, 11:59:49 am »
Thanks Mike, really enjoying the teardown, also those knobs look shiny !  ;D
The following users thanked this post: laptopmd
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: January 27, 2012, 12:36:18 pm »
Thanks Mike.  Luckily the grime on knobs and body is commonly due to our body oils by touching it; luckily most of such grime we create can easily be washout out with just regular soap and water.  I do the same, soak in soap, to save labor; another item that helps is warm water.  If you have one handy, a burst with ultrasonic cleaner will loosen anything further.
Always good to see a well made device.  The scope is made in Malaysia too isn't it?  It lists for about $12K US, has the price changed markedly in all that time?
Best Wishes,
 Saturation
Offline Rufus
« Reply #3 on: January 27, 2012, 12:54:42 pm »
Thanks for the show. Makes a change seeing you tear down something you have to put back together afterwards :)
« Reply #4 on: January 27, 2012, 08:46:34 pm »
Think it was about GB£6500 when I bought it about 8 yrs ago, but a year or two later they made 8M RAM and 3yr warranty standard and increased the price.
Offline Kibi
« Reply #5 on: January 27, 2012, 09:46:34 pm »
Thanks for this Mike. Very informative, as is to be expected of your video's.
Offline Drirr
« Reply #6 on: January 28, 2012, 05:27:16 pm »
Nice video, thank you !
Offline kaz911
« Reply #7 on: January 28, 2012, 05:57:49 pm »
Yes thanks for the video that was great as usual.
I usually use crushed dishwasher tabs for hard cleaning / soaking. I have not tried washing powder. :-) but will try that next time.
Regarding normal soap: Dishwasher tabs and washing powder contains enzymes that break down organic matter. That is why they usually work better than normal soap.
