For the most versatility, you might want to look at a dual 30V supply that can be wired in series for 60V. So you get hobby electronic voltages (plus you can also wire them to give you a +/- dual rail supply for op amps and the like) plus the 60V you need for electroplating work.
Specific choices, I'm watching along with you, My only bench supply is an HP 3610A, which is a single supply good for 8V at 3A or 15V at 2A max. Old but solid, and you can get them on ebay fairly cheap. No fancy computer interface stuff or programmability, just dial in the voltage and current limit. And they are linear, not switching, so low noise. A decent dual supply is maybe the only other bit of kit I could use on my bench, although so far nothing I've been doing would need it.
