Author Topic: Coldfusion 4.5 digit LED 2V panel meter  (Read 14328 times)
Offline silicon_ghostTopic starter
« on: August 08, 2012, 12:32:41 am »
I recently purchased an inexpensive, high accuracy panel meter.  This particular model was USD19.50 plus shipping.  They are sold from both Lightobject.com (http://www.lightobject.com/Search.aspx?k=4.5%20digital%20meter) and eBay (http://stores.ebay.com/coldfusionxelectronics).
Most panel meters in this price range are either LCD (bleh), or only have 1 or 2 digits of precision.  It is a 4 wire design using 5V power.  I've included a snapshot of the advert on eBay and I took a few action pictures after doing a minor bit of calibrating the unit.  The measurement is darn near spot-on with typical error of less than 1 or 2 least-sig digits.  I checked it against my precision voltage references from http://voltagestandard.com (my thanks to whomever talked about these cheap voltage references).
Offline T4P
  • Country: sg
    • T4P
Re: Coldfusion 4.5 digit LED 2V panel meter
« Reply #1 on: August 08, 2012, 03:12:24 am »
What IC is it based on? I have my bets it's a ICL7135
« Reply #2 on: August 08, 2012, 04:26:01 am »
You may be right.  It is a 28 pin chip.  TI lists only DIP but their website indicates a number of second source manufacturers.  The IC has been sanded down.  I don't see any indication that there is recoverable info.  A quick glance through gaps between the LED panel and the PCB shows that all of the components are on the top layer of the board.  Here are a couple photos.
Offline T4P
  • Country: sg
    • T4P
« Reply #3 on: August 08, 2012, 06:15:10 am »
It isn't the ICL7135 at first glance
ICL7135 pin 1 is V+
I think it's a uC of some sort, can't really see anything beyond all the awful flux remains
Offline jusanother
« Reply #4 on: August 10, 2012, 10:32:01 pm »
Many thanks for taking the time to review the eBay find, nice pictures. Can I ask is the -ve input is tied to the supply -ve ? The reason I ask is I have one of these:
http://www.ebay.co.uk/itm/4-1-2-Digital-DC2V-Voltage-Panel-Meter-Voltmeter-/320684620851 (ICL7135 based)
seller: mib_instruments pic: attached
On this model the two -ve's are tied together on the PCB, and I suspect it's causing me problems when measuring low (>10mV) voltages that are derived from the same source as the meter is powered.
Any observations gratefully received.
Cam.
« Reply #5 on: August 11, 2012, 12:39:53 am »
It appears that they are tied together.  I got less than 1 Ohm when I checked resistance between the two leads.
Matt
Offline jusanother
« Reply #6 on: August 11, 2012, 07:44:23 pm »
Thanks for checking that, looks like I'm either using two supplies, or building my own meter, ah well. Shame they are wired this way, true differential would be better. My module draws 100mA ish, the ground lead supplying it measures @ 58mohms, giving a drop of 5.8mV from the real ground potential. Guess this is my prime suspect.
« Last Edit: August 11, 2012, 10:45:48 pm by jusanother »
« Reply #7 on: August 12, 2012, 06:00:03 am »
Get one of those 1W modules Dave was testing, should be perfect for this application.
Offline jusanother
« Reply #8 on: August 14, 2012, 02:09:21 pm »
Well one bodge wire and a little pcb ground plane hacking later and I have separated the -IN from GND, the meter is much better in my application now. Not pretty but beats a PCB redo for this one off. If anyone is interested the project was a redo of the old EDN battery internal resistance meter, updated the original to give it 3 ranges, works pretty good.
SeanB: What is this "1W modules Dave was testing" you speak of ?
« Reply #9 on: August 14, 2012, 06:21:06 pm »
Look at his recent videos and you will get the DC-Dc converter testing.
EEVblog episode 324.
Offline jusanother
« Reply #10 on: August 15, 2012, 05:19:05 pm »
Ah yes got you now. Cheers.
Offline ViewPoint
« Reply #11 on: September 28, 2015, 07:29:15 pm »
I am planing to buy a PentaRef  from
voltagestandard.com
Is the board in the specification?
Best
« Reply #12 on: October 07, 2015, 08:36:08 pm »
voltagestandard.com
Best
Do you mean is the PentaRef within its specs?  Voltage Standard does provide the accuracy to be expected from the unit.  All of my voltage standards from them have performed well when I've cross checked them against other devices.
