Author Topic: Korg Monotron, Monotribe  (Read 2230 times)
Offline andrewkirkbyTopic starter
« on: October 14, 2013, 09:29:51 pm »
I'd be very surprised if anyone here hadn't tinkered with Korg's analogue synthesisers. They're back end is open to hacking both hardware and firmware (although the firmware side of things is a bit odd following Korg's update method).
My question is has anyone done much in the way of modding these? I'd like to get a few ideas and because I'm not the most clued up with synthesisers, I'd like to learn a bit too in the process.
On a side note, I'd like to add a midi mod to the monotribe which I guess would involve using an optocoupler but I'm a bit unsure on the circuit required. I do however know paying someone $70 plus shipping from Brazil is a bit overpriced for a pair of midi connectors and a few £ of components..
Offline AndreasF
    • mind-dump.net
Re: Korg Monotron, Monotribe
« Reply #1 on: October 15, 2013, 07:41:07 pm »
The MIDI input side using an optocoupler is indeed quite trivial and examples are very easy to find. E.g. the official MIDI manufacturers association has a sample circuit diagram here.
my random ramblings mind-dump.net
Offline fcb
    • Electron Plus
« Reply #2 on: October 15, 2013, 07:54:20 pm »
Sticking MIDI on the monotron is non-trivial, and yes the parts aren't expensive - your paying for labour and know-how.
