This might be of interest:
The video is in German and has terrible audio quality, but there are English subtitles.
If your control board's the same as the one in the video, perhaps you might also be able to get the UART going?
I have a more recent NANKADF WPS3010H. It looks identical on the outside but has a different control board (WT300-PCWU-PC2-NWT 2022-06-20 v1.0). The board is based around an
MS51FB9AE MCU and also has an unpopulated header connected to the MCU's I2C/UART/ICE pins. I tried to get it going on the assumption that it might be configured as a UART but so far haven't had any success.
The firmware on the power supply has functions to configure UART and Modbus parameters (baud rate, device address etc), which seems to suggest it's not completely unaware of serial comms.
If anyone else has tried this, I'd love to hear how it went.
P.S. The header pinout is as follows:
- R (reset?) - MCU pin 4 (nRESET / P2.0)
- D (?) - MCU pin 8 ([I2C0_SDA] / UART1_TXD / ICE_DAT / P1.6)
- G (ground?) - MCU pin 7 (VSS)
- S (?) - MCU pin 18 (P0.2 / ICE_CLK / UART1_RXD / [I2C0_SCL])
- V (VCC?) - MCU pin 9 (VDD)
The labelling of the D and S pins is a bit of an enigma. Would love to hear your best theories for what the two letters might stand for!
