Electronics has always been a hobby for me and I've been out of the game for 5+years. I've been getting back into this stuff in the last month or so but some of the complex stuff still confuses me. So my fundamentals are sometimes rusty with embarrassing errors.
So I made a diagram to try and outline the differences between using a KSGER handle or an Aixun handle, and the differences between the two. The diagram is intended to be printed out on A4 paper in landscape orientation.
For example, if someone wants to modify one handle to work with the other, like using a KSGER handle for Aixun, or the C245 mod with custom firmware for KSGER/QUICKO. I've had a hard time finding information of the C245 wiring, I found one diagram but it's not labelled in terms of which station it's designed to work with. If anyone has experience with Aixun stations, does this wiring look correct? And for those that have done the C245 mod for KSGER stations, will this wiring work ok?
For the 5 core wire, red and blue were joined together on Pin 5 for a little bit extra current capability, but you could just as easily snip the blue wire and put heatshrink on it. Or use the blue wire for the Pin 1 shake switch to ground. The diagram assumes no shake switch, and for using the stand for activating sleep.
Any thoughts or criticisms are welcome. The main ones I'm unsure about are the C210 for use with T3B and C245 for KSGER/QUICKO.
