Author Topic: China LC200A LC Meter Teardown  (Read 29430 times)
Offline MechatrommerTopic starter
  • Country: my
  • reassessing directives...
« on: December 13, 2011, 10:15:28 am »
recently came up somewhere here. so i bought to try one, along with other items from China. for $43 i thought it is just a pic LC module kit with nice casing, turned out to be different. bought from ci_tynight209 (i will recommend this seller as they are very helpful and responsive imo). http://www.ebay.com.my/itm/L-C-Inductance-Capacitance-Multimeter-Meter-LC200A-Tool-/170674919477?pt=LH_DefaultDomain_0&hash=item27bd049835 if you ask me... i'm happy. pictures worth 1K++ words.
The following users thanked this post: elecdonia
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: China LC200A LC Meter Teardown
« Reply #1 on: December 16, 2011, 05:39:38 pm »
Thanks mecha, for making the review and teardown.  It looks like a decent LC meter to give you ball park figures.
The links states they use 500 kHz and 500 Hz.  Most manufacturers spec their products at 1kHz or orders of magnitude from 100 Hz: 1kHz, 10kHz, 100kHz, 1 MHz.  The measured value from this device should still be close though.  It would be better to also have DF or Q.
Best Wishes,
 Saturation
  • Country: my
« Reply #2 on: December 16, 2011, 06:38:05 pm »
sometime it can go up to 600++KHz. yup its good to have if other parm can be displayed, but at $40, i think there's no competition for low valued capacitance and inductance measurement. its very hard to find such device, the closest i searched sometime ago is lab quality thousands dollars tag. the commonly mentioned LCR meter around here can price minimum $100 (normally $300), which still dont go down to pF and sub uH level reliably. so this china designer is a bless for me. from my experience with it, i can say the reading are repeatable (as long as we keep remembering to zero everytime when changing range hi/lo l/c), about the accuracy, i dont have anything else to test it with, i will not be optimistic on that, but hey, at least i can sort back my caps and inductors on the table back to their appropriate bag, thats the main mission i bought this :D, and 2nd, since its expendible, i can make teardown as much as i want to :) i already made my custom probe/rig for it. and i use it with my generic wallwart, no need to worry the 4xAA.
Offline grenert
« Reply #3 on: December 16, 2011, 07:43:32 pm »
This LC meter kit will go down to .01 pF and 1 nHy.  Kit is $100 plus shipping ($6 in the US, $12 elsewhere).
http://www.aade.com/lcmeter.htm
They have lots of accuracy and repeatability information for the meter on the site.
Offline RCMR
« Reply #4 on: December 16, 2011, 08:16:26 pm »
I recently bought this one but haven't had a chance to try it out yet.
http://www.goodluckbuy.com/lc100-s-l-c-f-inductance-capacitance-high-precision-meter-board.html
Looks somewhat similar but is only $37
  • Country: my
« Reply #5 on: December 16, 2011, 09:07:54 pm »
yes i believe its similar except older version. previously mentioned seller also sell it for $33 http://www.ebay.com.my/itm/High-precision-L-C-Inductance-Capacitance-meter-LC100-A-/170674919437?pt=LH_DefaultDomain_0&hash=item27bd04980d if you want to save $11 and dont care about the casing/batt compartment and older version 1 than, thats another option.
  • Country: my
« Reply #6 on: December 16, 2011, 09:16:52 pm »
this is the manual http://mpl.jp/lc/LC200A%20%20EN%20V5.0.pdf accuracy reported to be somewhere similar to aade above, more or less, but who knows?
« Last Edit: December 16, 2011, 09:45:39 pm by Mechatrommer »
Offline nukie
« Reply #7 on: December 19, 2011, 08:18:45 am »
It looks like it was made by the same chaps who made the dds function generator, ST chip for I/O and that motorola buck boost chip.
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #8 on: December 19, 2011, 06:32:17 pm »
I think people are still mistaking resolution for accuracy! They are quoting between 1 and 5% accuracy, which is probably more hope than measurement. The use of the word "precision" in association with any of these designs is amusing to say the least.
Offline RCMR
« Reply #9 on: December 19, 2011, 07:25:42 pm »
Yes, but as my tailor tells me... "forget the quality, feel the width!"  ;)
