Do you still have this meter? If so how has it performed for you?
I'm asking because I have just bagged one on Ebay, not sure if it works or not at this stage as the seller did not have a power cord for it. If it works OK or I can get it working, I was thinking about the possibility of adding some leds around the screen to improve the readability assuming there is sufficient access to the screen for this?
