So I got one of these TL866A's from eBay to do some flash programming and it seems to work well on a 5x7 PLCC flash IC that I have. I also pressed a piece of sram against an adapter board and got it to test that successfully too. My question is, being that it is universal in nature, can it damage an IC if you select the wrong one and try to do an operate on it?
