http://nantero.com/Carbon nano-tube based memory tech. Is it legit? Looks like it.
"Nantero’s NRAM is as fast as and denser than DRAM, nonvolatile like flash, has essentially zero power consumption in standby mode and 160x lower write energy per bit than flash, and is highly resistant to environmental forces (heat even up to 300 degrees C, cold, magnetism, radiation, vibration). NRAM is compatible with existing CMOS fabs without needing any new tools or processes, and it is scalable even to below 5nm. Given that it requires a small number of process steps and only one mask layer, NRAM can be fabricated at low cost, and is compatible with both 3D multilayer architectures and MLC operation. This makes NRAM the ideal solution for the next generation of memory technology for both standalone and embedded applications."
