Well I didn't actually want to do a review but I seem to have a problem with this chip.
http://www.onsemi.com/pub/Collateral/NCL30160-D.PDFI wanted to use this chip to drive a string of 10 cree leds from 36 volts dc for domestic lighting.
I drew up a board and sent it to olimex for fabrication, it hasn't arrived yet, 3 weeks since it was sent, I am losing hope.
I bought five of the chips, a couple extra, in case I burnt one.
Anyway when I got the chips I went into prototype phase, and one by one said bye bye to my chips.
Chip 1. Sloppy handling, no esd protection, never worked, my fault.
Chip 2. I had no esd mat but I observed as well as I otherwise could ESD safety. Chip worked, went into hysteris mode but doesn't dim. my fault.
Chip 3 soldered onto dip converter board, was trying to hurriedly connect wires and wife called me to get into car, just as I was connecting 28 volts to power pin, but I got the wrong pin. my fault.
Chip 4 soldered into dip board, placed into breadboard everything good, we have light. we have dimming, I left it on for a few hours, once I cranked it up to 800mA, I checked the chips temperature, it did seem surprisingly cool. I put it back down to 300mA. All good until I disconnected one banana plug from the psu. Simulating a switch turning on and off. When I reconnected after say 1 second, the chip went short circuit. I assumed it was the Fet but it was the internal voltage regulator that is short.
Chip 5 was going fine for one hour, I left it running at 130mA for another hour, when I came back into the workshop, the workshop was quite smoky, the fire alarm hadn't gone off and the power supply was showing 450mA and was being current limited.
I contacted OnSemi just to see what they would say, they said it probably overheated.
I'm not worried, I might go back to a Amtel solution with discrete power components, but I am disappointed as I had high hopes for this chip.
Also I realise breadboarding fast power circuitry is not good but I don't think that is the main problem.
My circuit was very close to the reference circuit.
I generated the square wave with a 555 at about 3 volts.
the 555 was regulated by a 7805 rated at 35 volts or so, which had no problems at the same vin as the NCL30160.
Lastly I have never before wasted more than 1 of an individual type of chip on one project in my life. Now I have done 5.
In short either me or the NCL30160 rate a Fail. Probably both.
