Author Topic: Step down voltage transformer  (Read 2563 times)
Offline mtc2629Topic starter
« on: March 30, 2014, 10:52:35 am »
I just wondering what step down transformer to get because i want the Hakko FX-888D Soldering Iron but it comes with the us plug any suggestions of how to fix that problem
Offline han
Re: Step down voltage transformer
« Reply #1 on: March 30, 2014, 11:21:58 am »
A picture explain everything
Offline sotos
  • Country: gr
« Reply #2 on: March 30, 2014, 11:47:22 am »
You mean the voltage, or the plug?
Offline sotos
  • Country: gr
« Reply #3 on: March 30, 2014, 11:49:13 am »
As I see oh the pcb the connections are for 220v. Why the step down?
« Reply #4 on: March 30, 2014, 11:54:24 am »
Different transformers for 110 and 220V, but same top PCB. Look carefully and you will see it is marked 100/220V.
Offline han
« Reply #5 on: March 30, 2014, 12:04:18 pm »
You right, only 220-240 V.
Offline han
« Reply #6 on: March 30, 2014, 02:48:08 pm »
Maybe not a best solution,
Did you have a unused transformer (from Audio amplifier or anything) that have both 110/220 primary winding?
I'm sure you can make step up/down with it...(after safely insulate the secondary winding)
about the rating just make sure the transformer is rated for more then 90W (as far i remember the heater have about 70W rating)
with the configuration:
0-110V
0-220V
step up/down..
