For what it’s worth, I use three irons regularly: a T245, a T245 with foam cushion, and the Ersa i-Tool nano (which is nearly identical to the i-Tool*, it just lacks the internal accelerometer and has a different plug). Since I just got the T245 with foam, I haven’t made up my mind about whether I prefer that or not. (It’s removable if I don’t.) But I clearly prefer the Ersa iron’s shorter overall length. I dislike the loooooong strain relief JBC uses. But this is personal taste, as I remember Dave expressing in the ADS200 video how he prefers that very feature. I also prefer the sculpted shape of the Ersa, to me it just sits in the hand really nicely. It’s light, probably lighter than the T245.
On the other hand, since the Ersa isn’t a cartridge heater system, changing tips is more time consuming. But if you put a separate tip retainer ferrule thingie onto each tip, it can be done completely toolless, even when hot.
The tip to grip distance is similar, I’d say, without them side by side to compare.
*the i-Tool originally shipped with an overmolded rubberized finger grip, while the nano and pico versions had solid plastic grips. Comparatively recently, Ersa changed the i-Tool to also have the solid plastic grip, so the three handles are now visually indistinguishable and largely share the same components. The nano and pico lack the accelerometer and use a different plug. The pico uses a cheaper heater module with plastic threads. In the picture in the first post, on the Ersa, see the bit of metal peeking out between the handle and the knurled plastic nut? On the pico, that’s plastic instead.
