Author Topic: BTX-208 solder fume extractor not working  (Read 1208 times)
Offline FaringdonTopic starter
« Last Edit: September 29, 2023, 05:47:02 am by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Online tggzzz
Re: BTX-208 solder fume extractor not working
« Reply #1 on: September 26, 2023, 10:20:38 am »
BLDC driver  FET has blown on BLDC driver.
Do you know how to remove the driver PCB?
Based on the (lack of) information in those photos, the surest way to remove the PCB would be to use a crowbar.
More sensibly, your company should simply buy another.
(I say "company" since your questions traditionally are "we" rather than "I", and I'm sure you wouldn't be so presumptious to use the "Royal we".)
The following users thanked this post: Faringdon
Offline thm_w
  • Non-expert
« Reply #2 on: September 26, 2023, 09:44:36 pm »
Is that silicone covering the screws? Probably just some screws to take it off.
Then measure the FETs to see if its just one or all shorted. The gate driver may have failed as well.
