Well I don't use JBC. Even with my Weller at 350 C of continuous use with lead-free solder, the micro-soldering tip only needs to be changed after 8+ months. Even then the tip was not unusable, I just wanted to change it. Although mileage may vary depending on the job, I believe JBC like all the quality brands will have tips that always deliver good performance. Maybe JBC can help with the data.
