Author Topic: Bismuth solder Sn43/Bi57  (Read 1744 times)
Offline Free_WiFiTopic starter
  • https://tinyurl.com/y5nhpt2x
« on: February 20, 2019, 12:24:15 pm »
Hello people!
I'm doing this thread to ask you,which Sn43/Bi57 solder wire brand do you know.
Basically i already use the genuine Cynel 60/40 and now i want to switch to another one,because of health reasons ....
Thanks to all for advices etc ..
Offline PedroDaGr8
  • A sociable geek chemist
Re: Bismuth solder Sn43/Bi57
« Reply #1 on: February 20, 2019, 04:51:12 pm »
As a chemist with a background in heavy metals, there are no common health reasons to avoid lead-based solders. Lead does not volatilize during soldering, only the flux; if you wash your hands after soldering you have eliminated essentially all routes of ingestion.  In fact, as lead-free solders often require more aggressive flux (which DOES volatilize) you can actually be making a less healthy substitute.
The reasons for switching to lead-free solders is entirely environmental. As in the environment lead can leach out as lead salts, which are MARKEDLY more toxic than metallic lead.
« Last Edit: February 20, 2019, 04:52:51 pm by PedroDaGr8 »
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
The following users thanked this post: oPossum, Ian.M, tooki, Free_WiFi
« Reply #2 on: February 20, 2019, 08:05:14 pm »
Im using the flux in the picture.
Online wraper
  • Country: lv
« Reply #3 on: February 20, 2019, 08:20:17 pm »
The right place for it would be trash bin.
Offline Gyro
« Reply #4 on: February 20, 2019, 08:21:13 pm »
That is presumably Rosin (and a nice lump at that). Rosin fumes are going to cause you far more problems than physical contact with metallic lead, although as PedroDaGr8 points out, it's a lot less nasty than the flux in lead-free solders.
From Wikipedia:
Prolonged exposure to rosin fumes released during soldering can cause occupational asthma (formerly called colophony disease[15] in this context) in sensitive individuals, although it is not known which component of the fumes causes the problem
Good ventilation and sensible hand washing are the keys to safe soldering.
Best Regards, Chris
Online wraper
  • Country: lv
« Reply #5 on: February 20, 2019, 08:23:14 pm »
Just good ventilation is not enough. Fume extraction is essential for avoiding breathing flux fumes while soldering.
Offline Gyro
« Reply #6 on: February 20, 2019, 08:34:00 pm »
Ideally yes, but more difficult to arrange in a hobby situation. A small fan blowing the fumes away from your nose and towards an open window is better than nothing.
P.S. A useful reference on fume extraction... http://www.hse.gov.uk/pubns/indg249.pdf
« Last Edit: February 20, 2019, 08:47:47 pm by Gyro »
Best Regards, Chris
Online Ian.M
« Reply #7 on: February 20, 2019, 09:12:34 pm »
Knocking a lump off that chunk of rosin, pulverising it and dissolving it in just enough 95% alcohol (denatured ethanol or IPA) to get a liquid with the consistency of runny syrup, that can be applied to the work in a controlled fashion using a small brush bottle would be a good way to reduce rosin fume exposure, as sticking the soldering iron bit in the rosin to melt some for use causes excessive and unnecessary fuming.
Alternatively, just stick a flux pen on your next parts order.   Any western brand of RMA flux from a reputable distributor will be fine, and will be less messy and more effectvie than making your own unactivated liquid rosin flux.
The following users thanked this post: Free_WiFi
Offline Gyro
« Reply #8 on: February 20, 2019, 09:34:22 pm »
Another thought. Is unactivated rosin flux going to be effective at the low melting point of Sn43/Bi57 (139'C)?
Best Regards, Chris
