So I was using my cordless M12 iron to tin some sheet before soldering together (I like to use a torch and clamps) and I left it upright turned on for like 2 minutes while I was cleaning the work piece before a re-flux.
The bottom of the metal shaft melted the plastic that it is threaded? into and started to sag. If it was placed over something resting on the beefy looking guard, the tip would melt free of the plastic and touch the surface. I don't know what bozo designed this shit. You can't turn your back for 2 minutes on this thing. 40 minutes of run time to ensure you burn your work bench down.
You might want to toss this thing if you own it, it requires a redesign to fix. Nice job with testing milwakee, perhaps you should improve tool quality instead of spreading your product variety out like oil on water.. try a thermal overload safety test for those high prices you demand
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
I bet they put the entire R&D budget into 'one key' blue tooth bullshit rather then trying to figure out if it can burn someones house down.. perhaps you need a thermal engineer instead of another code monkey... have you heard of this? All I hear is battery life and one key..
![Rant :rant:](https://www.eevblog.com/forum/Smileys/default/rant.gif)
no one gives a shit, just make it not break catastrophically and you will own the market
